a word of warning to remember when putting your engine and box together
spent two hours wrestling with the flywheel clutch box
then saw this
can you spot the not so deliberate mistake
lol fixed now but still kicking myself
Crank sensor is going to be a loose fit......
I did this, only I fitted and plumbed the engine in before I realised that I'd made that mistake!
I think I spent longer looking at it in disbelief than it did to pull the engine and fit one!
yep that's right boys crank sensor mount that bolts in under the flywheel
so glad im not the only one
Slightly OT, but where did you get your crank breather plate?
Dave
Again only a little a little OT
Do you have a spare housing for manual gearbox C/S?
Nobody is perfect at least it is still on the bench.
Regards
ALLAN
ebay then drilled and tapped myself think it was £20 and ill have a look for a spare when I get home might have one
