Is it aluminum or an aluminium based alloy?
I ask because I have one which was once painted. After a few years sitting in a damp shed the paint is flaking badly with white powdery residue
everywhere...
I don't intend to repaint it but want to know what I'm leaving exposed.
its a cast Aluminium Alloy (don't ask me exactly which one though) - pure Aluminium isn't used for much, its far too soft (although it is
pretty good for corrosion resistance)
these were never painted on the original cars and they've lasted all this time in all weathers - so I don't think you need to worry much
paint doesn't stick well to to aluminium and its alloys, it needs really good prep work and/or etching primer to last
[Edited on 23/7/2018 by mcerd1]
Painting aluminium without proper preparation/Materials is worse than leaving bare.
minor defects on coating and or chips will allow moisture to enter the space between paint and metal and this in turn will start filiform (sp?)
corrosion.
Which looks as you describe.
Regards
AA
Anorak on.
It's almost certainly Aluminium Silicon, as silicon lowers the melting point and improves fluidity making it easier to cast.
To a certain degree it increases strength, although strictly speaking it makes the casting more rigid, and less ductile.
It decreases the coefficient of expansion (shrinkage and distortion) which is another bonus when casting.
It's also cheap as chips, being one of the most common substances on/in the planet.
The white powdery surface is aluminium oxide.
When steel oxidises it forms flakes, the flakes curl up and allow air and moisture under the flake so that a new flake forms underneath.
That's why left to it's own devices steel corrodes all the way through.
When aluminium oxidises it doesn't flake, in fact quite the reverse. The surface oxide forms a protective layer thus preventing
further oxidation of the aluminium underneath.
At this very moment my car is in the garage forming its very own protective layer.
Anorak off
Paul G
Paul G
Paul G
On bare aluminium that is true, but on coated aluminium, under certain conditions, the coating overcomes the protective layer and produces filiform corrosion as stated above.
Case in point the white powdery substance that jps describes.
Paul G
Interesting - I had always assumed that the white reside was simply the aluminimum equivalent of rust (and behaved accordingly) whereas this suggests it behaves somewhat differently...
