Redtop 20xe cambelt
AndyGT - 28/4/19 at 01:55 PM
Hi all
I have just changed the cambelt on my 20xe motor and have counted 14 teeth between cam marks. With cam lobes the tooth count was 15 as inlet need some readjustment. Does this sound right? The marks on the cam cover don't really line-up correctly....
I will try to upload some pics in a few minutes....
Thankyou very much in advance..
AndyGT - 28/4/19 at 02:02 PM
I have tried to attach photos but no luck. Message is below. The cambelt is the square type and has a manta cam wheel on exhaust cam. Thanks again in advance.... ANDY
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
I have an error message from my phone, is there a format restriction for images? Maybe resolution? Filesize? Dimensions?
