Aluminium Pipe supplier
shindha - 29/8/19 at 10:38 AM
I'm after some aluminium pipe 30 ID and 32 OD it's for cooling, needs to have a little bend in it 20 degrees, 10 inches on one side and 8 on the other and beaded both ends, does anyone know where to get some in the midlands.
[Edited on 29/8/19 by shindha]
nick205 - 29/8/19 at 02:53 PM
Does it have to be Aluminium?
Don't know if Copper's available in that diameter, but Cooper tube with solder ring fittings on the ends might give you what you need. Copper tube's not that hard to bend either.
A quick look online seems to suggest Ø28mm then Ø35mm Copper tube sizes, but I don't see Ø32mm.
[Edited on 29/8/19 by nick205]
cliftyhanger - 29/8/19 at 04:09 PM
a cranked aluminium aerial mast should have "about" the right bend....
https://cpc.farnell.com/blake-uk/a24/aluminium-crank-6ft-x-1-25-16g/dp/AP03162 but plenty out there
40inches - 29/8/19 at 05:57 PM
That's what I used, very light, easy to swage and cheap as chips.
I got mine from Wickes for about £1 more than Farnell, but no postage
