leaking MT75 Gearbox
axle - 12/4/24 at 11:05 AM
Hi all
I wonder if anyone has experienced the above matter. I see small amount of oil leakage from MT75 gear box the car has been off the road for the last few month . The leak seems to be coming at the rear top around gear selector. Sorry can not be more accurate as the view is a bit restricted.
Mr Whippy - 12/4/24 at 12:04 PM
Have you check the breather hole or pipe? if blocked and the gearbox heats up, the expanded air pushes oil out past the seals or anywhere it can.
here you go -
[Edited on 12/4/24 by Mr Whippy]
axle - 13/4/24 at 07:29 AM
Thanks for your reply , I shall.
