Type 9 Speedo Sender
MKMike - 24/5/08 at 12:53 AM
I found a type 9 in a scrapyard, no idea what model it came from, it has what appears to be an electronic speedo sender in the location where the cable would normally go. The sender has 3 wires coming from it.
Does anyone know how to wire it or know what colour code on the wires is?
I'll be fitting an electronic speedo so I'd like to use it if possible.
jollygreengiant - 24/5/08 at 07:39 AM
I think you will find the answer here.
Linky to wiring eplanation
But also you will have three wires, IIRC, Black, Brown and Yellow.
Brown should be earth. Black should be +12v supply and the Yellow should be the signal wires to the speedo head.
[Edited on 24/5/08 by jollygreengiant]
David Jenkins - 24/5/08 at 08:49 AM
If anyone has one of these speedo senders going spare then please let me know - I have a box with a big gap where the sender should go!
chris_smith - 24/5/08 at 12:19 PM
anyone got a pic of what your describing on the type 9 (so i know mine is still there)
jollygreengiant - 24/5/08 at 03:17 PM
Not the clearest of photo's but might give you the idea. Taken looking vertically down from the top, nearside of box just in front of gear lever.
electric speedo drive T9 insit
