dogwood
posted on 7/11/08 at 09:08 PM |
Rad plumbing
As I am intending to fit my engine tomorrow. I have just been sitting her thinking about the rad plumbing
Can you guys have a quick look at this diagram and see if it looks right.
Also does the 3 breathers by the question mark just T together or have I missed something?
Finaly, I seem to remember there was a pipe to the inlet manifold. Mind you that was a few months ago, so it could have just been a breather or
something.
Anyone put me right
blakep82
posted on 7/11/08 at 09:24 PM |
does a cooling system HAVE to have a header tank? I'm sure they never used to... whats the benefits of having one? not wanting to hijack, just
thought i'd ask
________________________
dogwood
posted on 7/11/08 at 09:28 PM |
No idea
But who am I to argue
FREE THE ROADSTER ONE…!!
philw
posted on 7/11/08 at 09:47 PM |
It either has one in the top of the rad, or a closed system like the one above doesn't it?
Must try harder
philw
posted on 7/11/08 at 09:48 PM |
thought i'd ask
As a matter of interest how are you routing your pipe work for the cooling system?
Must try harder
blakep82
posted on 7/11/08 at 09:51 PM |
i was thinking both my BMWs had an expansion bottle built into the radiator itself, which is ok, but the likes of my old mini didn't have one at
all.
i'd like to keep mine simple, 2 hoses between radiator and engine and thats it sort of thing. i've not given a great deal of thought to it
yet, just thought when i saw this thread. i'm not using water heated heaters inside. just electric ones (whenever i get round to fitting a
windscreen. or i'll look for a heated windscreen)
anyways, sorry, this thread isn't about my car
David, i'm pretty sure you can just join those up with a T peice. i think the top of the header tank is supposed to feed back to the top of the
rad? or is it the bottom of the header feed the rad?
[Edited on 7/11/08 by blakep82]
philw
something.
Anyone put me right
My header tank has two breathers on it, so one from the rad goes there as does the one from the thermostat, the breather from the inlet i just blanked
off.
Must try harder
philw
posted on 7/11/08 at 09:55 PM |
Yeah i know, but as your running an Ecotec i just wondered how you are doing it?
Must try harder
blakep82
posted on 7/11/08 at 09:59 PM |
cool like i was saying above, i hadn't given much thought to it, but had just thought 2 pipes between engine and rad. thermostat blocks off
the top hose (i think) and bottom hose connected as normal. ii've blanked off the water connections on the back of the engine (the ones the coil
pack sits on) still considering where to put the water temp sensor. probably in the top hose.
i have to say, i don't know much about plumping cars. in building the car, its becoming apparent i don't know much at all about cars
Canada EH!
posted on 7/11/08 at 10:21 PM |
Rad plumbing
Off topic, new cars have expansion tanks because the radiator cap is lower than the water passages in the cylinder head. Your old MINI didn't
need one because the rad cap was the highest point in the system, and when it got too hot the valve in the cap lifted and blew the coolant all over
the road. These are greener times and we try to keep the fluids in their proper place.
blakep82
posted on 7/11/08 at 10:23 PM |
ah, is that what it is! my radiator 'should' be higher than the engine, so i could get away with a simple radiator with pressure cap up
front just plumbed into the engine?
posted on 8/11/08 at 08:04 AM |
hmmmm, new cars don't have radiator caps.
the expansion or header tank is there because as water is heated up, it expands - these tanks allow the increased volume of water to go seomwhere.
As ^^^ said, mini just pi$$ed it onto the road, so when when the water cools, there is less water in the system. The tanks allow the water to return
back into the cooling system.
Back on topic.
Yoou don't say what engine it is but if a car engine, the water pump will have an outlet that goes to the heater and another to the manifold -
if you have not heater, then connect the two together.
your plumbin look fine to me but a) you radiator should not have a cap and b) you header tank should sit atthe highest point i nthe system; it should
have the cap.
ballcock
posted on 9/11/08 at 01:50 PM |
The expansion tank is there as said to allow the water to expand when heated this will only be effective when there is enough air in the tank to
compress, the old radiators were never filled to the top again allowing an air pocket for the water to compress, the rad cap is a pressure relief
valve design to release excessive pressure in the system this could in theory be placed anywhere in the system but is in general at the highest point
to assist filling and venting, the breather pipes are to allow trapped air to vent to the tank thus allowing the system to flow correctly hopefully
without airlocks restricting the volume of water flowing. If the expanion tank is not large enough to allow the expansion of the coolant at max
temperature then a expansion vessel as fitted to a central heating boiler could be plumbed into the system to add extra capacity.
dogwood
posted on 9/11/08 at 09:01 PM |
Ever felt Hijacked ??
blakep82
posted on 9/11/08 at 09:05 PM |
sorry
dogwood
posted on 9/11/08 at 09:14 PM |
No prob's
Vindi_andy
posted on 10/11/08 at 12:28 PM |
I know this will seem like a bit of a hijack but its all along the same line ie plumbing.
I have fitted a coolman rad, due to space constraints, which obviously has a pressure cap. I have also fitted the expansion tank from the original
cooling system. at some point I need to do my plumbing.
Should I route the pipe from the rad neck to the expansion tank or should I just blank it off and return it to a sealed system or is there a non
release cap that would do the same thing.
[Edited on 10/11/08 by Vindi_andy]
ballcock
posted on 11/11/08 at 10:44 PM |
If the pipe in question is the pressure relief pipe (above the sealing washer of the cap ) it should be pipe to a lower pressure collection bottle not
the expansion bottle which would be under the same pressure that you would be trying to relieve.
