Author: Subject: Making bends in exhaust
speedyxjs
posted on 8/11/08 at 01:22 PM Reply With Quote
If i were to buy a straight peice of exhaust and cut slots in to make a bend and weld them back up, would this be acceptable?
Im just thinking it would be cheaper than to buy bends sepatate.
mr henderson
posted on 8/11/08 at 01:46 PM Reply With Quote
You would be reducing the internal diameter of the piping, therefore restriciting the gas flow, but if that isn't a problem then why not, go for it
John
takumi
posted on 8/11/08 at 01:47 PM Reply With Quote
Yea , it does work, but the radius has to be quite large, as it becomes increasing impossible to fill the pleated gaps
I would buy a 3 or 4 90degree bends, and cut them up into the angles you need and butt-weld them to make up your exhaust.
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
Triton
posted on 8/11/08 at 02:20 PM Reply With Quote
If you are careful with your cutting and ensure no nasty gaps then tig weld it you will be ok... a fella who made exhausts for Jedis with CBR600 motors did it the very same way as couldn't buy or even make the tight bends needed......sure Formula farce pipes are made like that but in that "tityrainman" stuff.
www.tritonraceseats.com
www.hairyhedgehog.com
speedyxjs
posted on 8/11/08 at 02:21 PM Reply With Quote
Ok il do that. Thanks
Triton
posted on 8/11/08 at 02:22 PM Reply With Quote
UMM i meant ...cut a series of short sections of pipe with angles that once joined form a curve....
ballcock
posted on 9/11/08 at 12:14 PM Reply With Quote
I always knew this as a lobster back bend cut through the pipe at an angle turn it through 180* reweld it you have a bend at twice the angle of the original cut. works well but is not very aesthetic.
