Author: Subject: sealing a concrete floor
locoboy
posted on 8/11/08 at 09:35 PM Reply With Quote
My garage floor is really dusty, its bare concrete and you could sweep it continuously and never get all the dust up.
The action of sweeping it just creates more dust and over time would expose the aggregate in the concrete mixture.
Can i seal it with anything - pva mixture perhaps? if so what ratios?
Ideally i want to paint it.
Locoboy
IDONTBELEIVEIT
posted on 8/11/08 at 09:39 PM Reply With Quote
i used THIS
Are We There Yet, Are We There Yet!!!!
adithorp
posted on 8/11/08 at 09:42 PM Reply With Quote
Floor paint maybe?
Do one coat with it watered down with thinners. That way it soaks in. Then a second coat without the thinners.
adrian
http://jpsc.org.uk/forum/
owelly
posted on 8/11/08 at 09:49 PM Reply With Quote
I had a similar experience but I tried Flor-tred paint but I used about a litre to do 2ftsquare because it kept soaking in!! Against the advise of a few learned folk, I mixed some Febond (PVA) 50/50 with water, paijnted the floor, left it for a week and then topped it with the Flor-tred. It worked fine. To be fair, the PVA mix would have sealed it for a finish but I had a small red square I had to make match!
http://www.ppcmag.co.uk
dhutch
posted on 8/11/08 at 11:14 PM Reply With Quote
Arse, just lot my post through not being signed in.
Basicaly, best bet is to hit the PVA, the follow with paint if required.
You can get a gallon of the stuff for buttons from the builders merchant, 50/50 mix with water, brush on with an old sweeping brush. Soaks in, and seals the floor. Then you do it again and in soaks in a little less and forms a fairly good surface.
You can then paint it, if you want it like that. Which makes it a bit more wipe-down-able. Although more slippy if you dont!
You can just paint it, but it might peel and lift a bit without the pva.
Daniel
rgr33n
posted on 9/11/08 at 08:15 AM Reply With Quote
i did the same as owelly and dhutch. works well enough for me. just used an "international" floor paint from B&Q and some PVA i had in shed. still fine 3 years on
posted on 9/11/08 at 09:20 AM Reply With Quote
.... and then afterwards you wantto put down carpet tiles, preferrably in brown.
Oh, hang on, I've got some goiong spare - see my post. Anybody want them?
Krismc
posted on 9/11/08 at 10:14 AM Reply With Quote
PVA Mixed down 4:1 mate, let it dry, sweep it and second coat it, then if you still a little concerned costco have a resin based floor coating for £40 it drys leaving you a water tight, 3 mm bed of vinal- just like the hospital floors- but very hard wearing.
geoff shep
posted on 10/11/08 at 08:18 PM Reply With Quote
I found the 'proper' stuff worked really well - concrete sealer followed by garage floor paint.
http://www.choiceful.com/disprod.php?pId=7956
locoboy
posted on 10/11/08 at 09:45 PM Reply With Quote
Thanks for the varied replys guys.
I will give the PVA a go first as i have 40mSq to do, the 'proper' stuff looks to work out fairly expensive.
Locoboy
Guinness
posted on 10/11/08 at 10:37 PM Reply With Quote
That reminds me, mustn't overlook the floor paint on the job I'm tendering for at the moment! 600 sq m of concrete to seal and paint. Better get a bigger roller!
Mike
posted on 10/11/08 at 11:18 PM Reply With Quote
I just mix the pva into the water till it looks milky, I don't usually measure it but I don't think it's as strong as 50/50 It does hold the dust down and make a good paintable surface though.
jps
posted on 27/3/16 at 06:42 PM Reply With Quote
Ancient thread resurrection I know, but it came up as one of the first pages when i Googled, so thought I may as well add here...
Have taken the 50/50 water/PVA advice from here. My garage floor was concreted about 13 months ago, ran over it with a brush and a Henry hoover to get it as dust free as possible, then went over it with the PVA mix. I mixed up ten litres (garage is about 16 Sq mtr) which did for two substantial coats, looked like spilt milk when it wen down but dries up with a glossy even finish. Top coat of Screwfix floor paint will be next. ..
Phil_1471
posted on 27/3/16 at 07:21 PM Reply With Quote
^^^ exactly what i will be doing this summer :-)
You can live in a car but can't rally a house
jps
posted on 1/4/16 at 09:10 AM Reply With Quote
Spent a couple of hours with a brush painting the garage floor with Screwfix No Nonsense Floor Paint last night. Left the doors shut to keep the moths out, regretting the lack of ventilation a bit today - feeling rather sick!!!
