Author: Subject: Acceptable FUEL LINE options?
muzchap
posted on 26/3/09 at 03:40 PM Reply With Quote
Sigh!
S2000 project is finally back underway after a slight detour on a CRF450R project
I'm close to having it running, only thing I need to sort is the fuel lines and wiring
I'm struggling to find enough 'clear' space through the transmission tunnel to mount the copper pipes and was considering options:
1) Copper
2) Rubber (proper fuel line with nylon strands)
3) Goodridge hose style - metal
I guess what I'm asking is what are the pro's / con's of each - I'm definitely trying to stay with copper, but could utilise the flexibility of the other 2 options.
Also - anybody know where to get any male/female ends like brake pipe unions for 10mm copper pipe - that would make it easier if I could join it in places
M
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
omega0684
posted on 26/3/09 at 04:06 PM Reply With Quote
goodridge is just far too expensive in my opinion although they are the nuts!
copper piping is a popular option, its cheap and easily managable. i would use rubber fuel line at each end and use fuel clips to attach
braided fuel lines (which i use) are a liitle more expensive but very strong and flexible, only downside would be is that you can't tell if the rubber on the inside of the pipe is perishing for whatever reason until there is fuel leaking throught the braiding (not common though)
muzchap
posted on 26/3/09 at 04:17 PM Reply With Quote
Cheers Omega
I previously used copper - think I'll take a look at the braided fuel lines on Friday
M
omega0684
posted on 26/3/09 at 04:37 PM Reply With Quote
i think my braided hose was about £8/ metre
NS Dev
posted on 26/3/09 at 08:28 PM Reply With Quote
Originally posted by muzchap
Cheers Omega
M
I used braided on mine, but the PTFE stuff like you use for brake lines.
You can get it in all sizes and its much cheaper than the rubber goodrisge stuff.
Have a look on think automotive website at TFE hose in -6 size
NS Dev
posted on 26/3/09 at 08:30 PM Reply With Quote
just looked, its 9.44 a metre plus vat but it will last a lifetime
muzchap
posted on 27/3/09 at 08:06 PM Reply With Quote
Hey NSDev,
Great to see you still on here
Think - I'll go order some now
How's things going?
M
NS Dev
posted on 5/4/09 at 10:29 AM Reply With Quote
Not too bad, been busy with work, and now possibly very busy with setting up in business with my brother!
Took the locost out last night and had some fun though!!
