po79
posted on 9/6/09 at 04:52 PM |
Pinto valve stem seal replacement
Hi guys,
My pinto engine has started to smoke on start up and I think its the valve stem seals as I've had this on a few of these engines in the past.
Someone mentioned the other day to me that they've seen or heard of a tool that allows the cylinder head to be left on and goes into the spark
plus hole to hold up the valve whist compressing the valve spring so you can remove the spring, replace the valve stem seals and put it back together
again.
Any ideas where I might get one of these tools or do you think its a home made tools?
Anyone ever bought one or made one?
thanks,
Po79.
g.gilo
posted on 9/6/09 at 04:58 PM |
pinto
used to be standard ford service tools when pintos were in there hayday, find a ford or ex ford tech hes bound to have them.
jollygreengiant
posted on 9/6/09 at 05:07 PM |
Last time I did them in situ, was when I changed the cam shaft. All I did was to make sure that the relevant piston was at TDC. Valves drop a
fraction, but not enough to be a problem. Then all I needed was the tool to compress the valve springs.
Something like this Linky
hope this helps
flak monkey
posted on 9/6/09 at 05:41 PM |
hope this helps
This method works like a charm....
Sera
http://www.motosera.com
SteveWalker
posted on 9/6/09 at 05:50 PM |
Take a look at http://nw.rhocar.org/seals.htm
SteveW
posted on 9/6/09 at 06:17 PM |
Might be worth putting your location in your profile , you never know someone in your area may be able to help with the tool? If your any where near
Cambridge I may be able to help
MautoK
posted on 9/6/09 at 06:37 PM |
I did this a few months back. Made a tool to compress the valve springs; and stuffed nylon rope into each cylinder in turn then raising the piston to
hold the valves closed.
No problems, but usual fiddles with collets.
po79
posted on 20/6/09 at 03:50 PM |
Thanks guys,
I've tried to post a reply (twice) to thank you all the other day but it hasn't been posted.
Anyway I've been in hospital for a few days but as soon as I recover from my op I'll have a go that the seals and let you know how I get
on.
Thanks again,
Po79.
