Author: Subject: Bike carbs on Zetec fuel return
RMarine
posted on 27/6/09 at 11:51 AM Reply With Quote
Hi, i am planning on using bike carbs to run my 2.0 zetec engine. will i need to install a second fuel line as a return ?
if so, does it need to be copper or rubber and what size? Thanks for you help.
tul214
posted on 27/6/09 at 12:09 PM Reply With Quote
If they are carbs...no return is needed.
However, if they are throttle bodies(injectors) then yes you will.
1.6 Raw Super6 sold
DRC INDY 7
posted on 27/6/09 at 12:10 PM Reply With Quote
no fuel line needed
Puddle Dodgers Club
corpi
posted on 27/6/09 at 12:11 PM Reply With Quote
If your are going to use them as carbs, there is no need for a return.
If you are going to use them as throttle bodies for an injected engine, then you need a return line & Hi pressure fuel pump and a swirl pot. The return will then be from the swirl pot to the fuel tank.
If you search on this forum you will find many refferences on this subject!
[Edited on 27/6/09 by corpi]
RMarine
posted on 27/6/09 at 12:25 PM Reply With Quote
this is what i plan on buying:
http://www.tiger-super-cat.co.uk/csc/fs_pdf/bike_carbs.pdf
Please have a look and any comments would be grateful... Thanks again
tul214
posted on 27/6/09 at 12:49 PM Reply With Quote
No return needed with those but you might want to budget for a bike fuel pump.
Also £375 seems a bit steep. Can you not make your own inlet manifold?
[Edited on 27/6/09 by tul214]
1.6 Raw Super6 sold
RMarine
posted on 27/6/09 at 01:19 PM Reply With Quote
i wouldn't know where to begin. thats why i am looking for a plug and play solution. i thaink i can get the carb kit and ECU unit , Zetec coil pack, flywheel position / speed sensor and connecting cable with plugs & sockets for £750.00
big_wasa
posted on 27/6/09 at 03:05 PM Reply With Quote
Thats an awfull lot of cash for what is still a locost setup imho
That sort of cash would get you a mint set 45's , ecu and the hole nine yards.
RMarine
posted on 27/6/09 at 03:19 PM Reply With Quote
REALLY... let me tell you guy's the full story and maybe you can save me a few pounds.. i am building a car without a instruction manual. Using common sense, photos, this forum and some phone conversions with the manufactures of the kit. most of the mechanical i can figure out. but when it comes to electrics and fueling i'm F**King useless. i want to buy a kit that i can plug the live in and then the earth, blot on a set of carbs and start the engine...... however i now realize that this is just a dream. i am going to be fitting a 2.0L zetec engine with a type 9 box. i have run one fuel line to the back of the car and have now got the loom sitting on top of the car......Whats Next??????Heeeellllpppp....
big_wasa
posted on 27/6/09 at 03:36 PM Reply With Quote
lots of options.
Less of your own work also = more dosh.
Just a few points ( my opinion )
• More power than Twin Webbers
Thats crap
• Smoother than fuel injection
Thats crap
• At £ 375 as cheap as one new weber
but the bike carbs are second hand.
[Edited on 27/6/09 by big_wasa]
RMarine
posted on 27/6/09 at 04:16 PM Reply With Quote
if i went for a set of 45 webbers, what esle would i need to get it to start? ie. ecu, brain, coil ????
RMarine
posted on 27/6/09 at 04:18 PM Reply With Quote
also is £150 +vat a good price for a 2002 2.0L zetec with 3 month warrentry?
RMarine
posted on 27/6/09 at 04:23 PM Reply With Quote
would these work?
http://cgi.ebay.co.uk/Webber-Alpha-twin-DCOE-45-Carburetors_W0QQitemZ300324450802QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item45ecbb7 1f2&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1689%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
jeffw
posted on 27/6/09 at 04:25 PM Reply With Quote
I have a set of GSX-R 1000 Throttle bodies re-spaced on a proper zetec manifold which you could have for £220....leaving you £555 (from the orginal £750) for the ECU and the rest of gubbins.
jeffw
posted on 27/6/09 at 04:26 PM Reply With Quote
The webers would work as well....
RichardK
Hi Mate
If you're at that stage, put another fuel line down the tunnel anyway as its much easier to do now rather than later, then if you ever decide to do the throttle body thing or webers that need a return you're all set.
Rich
Gallery updated 11/01/2011
RMarine
posted on 27/6/09 at 04:29 PM Reply With Quote
Hi Mate
Rich
What size fuel pipe ?
tul214
posted on 27/6/09 at 04:52 PM Reply With Quote
I have a set of 45 dellortos with a tps fitted you could have for £200.
You would still need an ignition set up and an inlet manifold.
Also have a fuel pump and regulator.
1.6 Raw Super6 sold
RichardK
posted on 27/6/09 at 05:37 PM Reply With Quote
I used 8mm like this stuff LINKY have a look what you've got going down already and get the same, you can then figure of 8 the p clips to secure both lines together.
Rich
big_wasa
posted on 27/6/09 at 06:22 PM Reply With Quote
I used 8mm aswell. I wish I had run the return whilst I was at it. Its now going to be a ball-ake.
big_wasa
posted on 27/6/09 at 07:21 PM Reply With Quote
them westi webers look fine but I would expect them to go for more ?
The ecu is a dealer only to re map so make sure your engine is the same spec.
The carbs should be the zetec spec 152g if not they will run very lumpy at low revs.
That kit would have cost well over £1500 new.
tendoshingan
posted on 27/6/09 at 10:17 PM Reply With Quote
Nobody has asked what year your zetec is.
If it's a new one you may not pass the emissions test running it on carbs
