Author: Subject: VW Polo Oil change - easy??
Beardy_John
posted on 18/7/09 at 01:28 PM Reply With Quote
Hi all,
While out working on my tin top a neighbor asked if I could give his Polo an oil change for him. Not a problem, but never having worked on a VW before, do I need anything special for the drain plug etc...
posted on 18/7/09 at 02:08 PM Reply With Quote
19 mm spanner IIRC although some later ones may need a special socket to remove the oil filter.
Beardy_John
posted on 18/7/09 at 02:17 PM Reply With Quote
cheers rusty nuts. I've got a chain strap wrench for oil filters, would that work?, or is it an odd shape?
stevem2727
posted on 18/7/09 at 02:23 PM Reply With Quote
looks exactly the same as a normal oil filter,but has a 27mm nut on the end.Most vws ive worked on have just had 19mm sump plugs,good luck
Beardy_John
posted on 18/7/09 at 02:57 PM Reply With Quote
Brilliant, cheers guys. Should see me get a few beer tokens next weekend then
geoff shep
posted on 18/7/09 at 03:59 PM Reply With Quote
Depends on the engine. This month's Car Mechanics mag shows a 1.4 petrol service including oil and filter change.
hillbillyracer
posted on 18/7/09 at 04:57 PM Reply With Quote
What age is it? Most of the recent VWs have the modern cartridge type oil filter with a plastic cap which you need a big socket to fit, 36mm I think. Despite the large socket sie they dont need to be tightened much, it may have the correct torque setting on the plastic cap. It's easy to deal with but you're gonna struggle without the socket!
My mate's 51 reg Golf TDI PD, the 07 reg T5 Transporter I occasionally see, & the 03 reg Golf V5 my sister had all use that type but my 51 reg T4 Transporter is an old fashioned spin-on filter.
Beardy_John
posted on 18/7/09 at 09:19 PM Reply With Quote
Its an N reg, so it should be an old spin on type with no socket required.
