Author: Subject: Skimming a head - have I just made a fool of myself?
Guinness
posted on 23/7/09 at 03:21 PM Reply With Quote
Took my cylinder head into a local engineering workshop this morning to get it skimmed.
The tollerance in the manual is 0.002".
They agreed to skim 0.004" off it and surface it. They knew it was a Kawasaki bike engine head.
Just been round to collect it and I wasn't (at all) impressed by the finish.
Basically either end of the head was absolutely mirror smooth, like glass. But in the middle (cylinders 2 and 3) it was like a record!! You could clearly see and feel the circular tracks where it had been cut.
They said that the gasket would cope with it. I said it was a multi layer steel gasket, and thought it would leak like a sieve. Honestly the groves were easily felt with a finger nail and right across the face of the head, connecting oil ways / water ways and the combustion chambers.
They have agreed to re-finish it and it'll be ready in the morning.
Question is, have I got them to do un-neccessary work, and made myself look like a tit?
They are the experts and have probably done more cylinder heads than I've had hot dinners, but, I just wasn't willing to risk the time / money in re-building the engine to find out that I was right and the head gasket couldn't cope with the grooves.
Mike
pewe
posted on 23/7/09 at 03:28 PM Reply With Quote
I would have thought it should have been equally smooth all the way across otherwise it's not dead flat, espec if they have put it on a surface plate.
Having said that its your money not theirs so your perogative to have it as you want it.
Hopefully they won't end up taking too much off - suggest you dry fit first to check clearances in case they have.
HTH.
Cheers, Pewe.
dinosaurjuice
posted on 23/7/09 at 03:30 PM Reply With Quote
your not an idiot.
youve seen how good the surface finish is at the ends. theres no good reason they shouldnt replicate that in the middle.
posted on 23/7/09 at 03:34 PM Reply With Quote
No Mike, you very clever and sensible...
Head skims need to be perfectly flat and mirror smooth. The grooves you describe may make the head gasket fail prematurely..
Andy D
posted on 23/7/09 at 03:51 PM Reply With Quote
I had exactly the same with mine. OK, it's a pinto, and the grooves must be for a 78 record!
Didn't notice when I clapped it together, but it would'nt seal. Had to have it skimmed again.
gaz_gaz
posted on 23/7/09 at 04:35 PM Reply With Quote
the finish is very important when using mls gaskets.
you done the right thing.
i machined a head for a customer a while back but it was porous, i told him it wasn't going to seal properly,
he told me he was going to use a mls gasket and hylomar blue on it,
week later he brought a replacement head in for a skim
[Edited on 23/7/09 by gaz_gaz]
balidey
posted on 23/7/09 at 04:44 PM Reply With Quote
difference in finish across the head shows its been done wrong / badly.
grooves you can feel with a fingernail are OK, but the smoother the better. They may have traversed too quick.
[Edited on 23/7/09 by balidey]
AdrianH
posted on 23/7/09 at 04:45 PM Reply With Quote
Not in anyway an expert, but I would have thought some roughness to the surface rather then mirror finish, reason for saying this is that when clamped down the gasket would be filling so,e of the imperfections and having more resistance to move under pressure. I would have thought that a mirror finish would not provide this, hard for me to describe so sorry if this is not making sense?
But groves over say one or two thou would be too much for the gasket to fill.
I may have something about finishes some where?
Adrian
Why do I have to make the tools to finish the job? More time then money.
scottc
posted on 23/7/09 at 05:47 PM Reply With Quote
Where was this Mike? I received good service from Northern Rebore.
Though this was about 2 years ago.
http://www.sotoconnect.com
Guinness
posted on 23/7/09 at 06:34 PM Reply With Quote
Hi Scott
No, not Northern Rebore.
I'll not name the company. Unless of course I don't get my head right!
Thanks for the rest of the input guys. I'll see what the morning brings.
Mike
[Edited on 23/7/09 by Guinness]
perksy
posted on 23/7/09 at 07:43 PM Reply With Quote
As has been said above if your using a steel 'layered' head gasket the surface needs to be Machined to the correct finish
I'd be taking it back and having a 'chat' with them
posted on 23/7/09 at 08:15 PM Reply With Quote
I reckon you are correct.
can't see how you can possible get gooves that you can catch your finger on unless there is some problem with the process.
posted on 23/7/09 at 10:18 PM Reply With Quote
I just had a Corsa head skimmed locally, it cost £25 and it was like a mirror finish. They pressure tested it as well and said it was o.k.
NS Dev
posted on 24/7/09 at 06:15 AM Reply With Quote
yep wot they said.
There almost certainly will be cutter marks, but you shouldn't be able to catch them with your nail.
That said, 4 thou isn't much, a lot of heads won't clean up at that, and if it was ok at the ends is could be that they have taken you literally on the 4 thou, rather than going a touch further to get decent cleanup
Guinness
posted on 24/7/09 at 11:48 AM Reply With Quote
Well head collected this morning. It's about 10x better.
However, I have to admit to a distinct loss of confidence in it, so I took it to Northern Rebore for a second opinion.
They passed it as an acceptable finish, but said they would have done better!
Just waiting on the gaskets arriving now, so I'll be spending most of the weekend lapping valves in and fitting them back into the head.
Mike
Mike
