Author: Subject: Nylon or similar material wanted
givemethebighammer
posted on 18/8/09 at 05:42 PM Reply With Quote
I need two strips of nylon or a similar tough, slippery material 30mm x 10mm x 2000mm. If any one has any or knows where I can get some in the Leicestershire area I have beer tokens waiting.
graememk
posted on 18/8/09 at 05:57 PM Reply With Quote
pound shop nylon chopping board
tomgregory2000
posted on 18/8/09 at 06:01 PM Reply With Quote
Wow i would like to see a 2m long chopping board
graememk
posted on 18/8/09 at 06:05 PM Reply With Quote
not hard to join, cut sand and polish.
givemethebighammer
posted on 18/8/09 at 06:25 PM Reply With Quote
lol
It's to fill the gap either side in an up and over garage door. Idea is to attach it to either side of the door so it comes down smoothly without catching on the stone door surround
(no frame attached to the stonework).
I'd rather do it in one piece than sticking lots of pieces together. I know nylon comes in 2000mm x 1000mm (ish) sheets so hoped maybe someone might have an offcut.
Mix
posted on 19/8/09 at 02:32 AM Reply With Quote
Hi
How about using 'P' section trim? Wouldn't this be easier to source and provide a better seal by virtue of it's compliance?
Cheers Mick
givemethebighammer
posted on 19/8/09 at 09:21 PM Reply With Quote
Originally posted by Mix
Hi
Cheers Mick
Thanks Mick, but it really does need to fill the gap between the door and the surround, it's a double door and it wobbles on it's runners as it comes down, sometimes catching on the stone door surround in the process.
