Author: Subject: Keep losing neutral?
Major Stare
posted on 1/9/09 at 10:31 PM Reply With Quote
R1 is running fine.... appart from buggered diff.
Noticed a couple of times when out and in the garage tonight... i cant get neutral sometimes?
Lever moves back and forth but i cant find neutral
Any idea's?
Jon "FISH"
posted on 1/9/09 at 10:38 PM Reply With Quote
Gentle touch or slight lever movement.
Should have bought a Kawasaki
Moorron
posted on 1/9/09 at 10:58 PM Reply With Quote
my zx12 is really hard to get neutral. my cbr was a lot easier with the same paddle system.
if i made it easy to get it, it would give too much movement for my liking so i put up with it.
Sorry about my spelling, im an engineer and only work in numbers.
ReMan
posted on 2/9/09 at 06:06 AM Reply With Quote
Normal.
As any gear, try getting it before you stop moving
daviep
posted on 2/9/09 at 06:35 AM Reply With Quote
Very common on a lot of bikes, often gets worse when they are hot.
Davie
givemethebighammer
posted on 2/9/09 at 11:54 AM Reply With Quote
Originally posted by ReMan
Normal.
As above
My Honda NC30 is hard to get into neutral if standing stationary. Trick is to blip the throttle to about 3000+ rpm and then it goes in easily.
dmac
posted on 2/9/09 at 06:49 PM Reply With Quote
As above, blip the throttle and slip it into neutral at the peak of the revs, works every time when you get the hang of it. It allows you to change with no pressure on the gears, drag from the clutch normally keeps everything in tension.
Duncan
Major Stare
posted on 2/9/09 at 08:17 PM Reply With Quote
Cheers guys.
Will give a go when back on the road..... see post on this section of the BEC forum
Jon "FISH"
