Author: Subject: Couple of (probably) basic problems
speedyxjs
posted on 3/10/09 at 03:44 PM Reply With Quote
My grandads mk4 (97) fiesta has a couple of problems.
Firstly the boot release doesn't work and secondly the indicators dont flash when the car is locked/unlocked. The wiring diagram in haynes manual doesnt show the indicators wired to the central locking but he insists they used to flash.
I have checked all the related fuses and they are all fine. Have checked bulbs too, they are all fine.
The other thing i have noticed is that the red light next to the clock (immobiliser?) is on all the time and doesnt flash.
Any idea's to any of the above?
austin man
posted on 3/10/09 at 03:48 PM Reply With Quote
I had an escort with a similar problem if I recall rightly there is a swithch / contact wher the hatch closes to the body I gave it a few light taps and plenty of wd40
tomgregory2000
posted on 3/10/09 at 03:55 PM Reply With Quote
are you sure the lights flash, brother got a 2000 focus and the lights dont flash on that, unless it has the same problem
speedyxjs
posted on 3/10/09 at 04:15 PM Reply With Quote
Im not but he is. I used to have a fiesta, same age, and that didnt.
MakeEverything
posted on 3/10/09 at 04:45 PM Reply With Quote
sounds like the alarm / immobiliser if it has one...
The lights wont be connected to the central locking, its the alarm that will flash the indicators.
Kindest Regards,
Richard.
speedyxjs
posted on 3/10/09 at 05:32 PM Reply With Quote
Any idea's where to start?
MakeEverything
posted on 3/10/09 at 06:06 PM Reply With Quote
Not really. Proba bly best to try the local ford dealer, or alarm fitter?
Kindest Regards,
Richard.
RickRick
posted on 3/10/09 at 07:10 PM Reply With Quote
my mk4 with key operated central locking didn't flash. mk 5 only flashed when the double locking was used, either with double click on the fob or turning key to unlock then lock
my boot relese on the mk5 was pap went back atleast 15 times got free service and cheep wheels out of it too, ford eventualy changed the whole boot lock mech including the solenoid. Easiest thing to rule out first is clean the contacts on the boot lid and shut, remove both the contact units and clean them inside and out
bi22le
posted on 3/10/09 at 07:39 PM Reply With Quote
Depending on the model of Mk4 Fiesta you can tell if it has an alarm. If it has an alarm the indicators will flash. Check that the bonnet and boot switches are working as this could cause both of your problems. The indicators may not flash becasue it thinks the bonnet is open (for example).
The ford alarm is where the central locking modual is. I thought this was the passenger side maybe in the kick panel. Get in the car and keep locking and unlocking the doors. Listen for the relay clicking and chase the noise. Thats where the alarm modual is. You will then be able to see if the indicator wires go in and out of the box.
Sounds silly but read the owners manual about the immob light. It may tell you something usefull.
I have not done this for some time, I am running from distant memories!!
Enjoy.
Please read my ring story:
200mph
posted on 3/10/09 at 09:20 PM Reply With Quote
my mk4 didn't flash when locked/unlocked.
also had similar problem with the boot and it was due to corrosion of the contacts. gave them a good clean and ensured the springs were free and it was sorted.
Mark
If it isn't broke, fix it until it is
