mr henderson
posted on 9/12/09 at 10:25 PM |
Fabricated front upright, anyone made one?
The topic of uprights crops up a lot, quite often in a 'which is the least unsuitable for my build?' type of way.
So I wonder if anyone has had a go at making their own?
MakeEverything
posted on 9/12/09 at 10:30 PM |
Was going to in acccordance with the Rorty drawings, but never bothered as i picked up some proper used sierra ones for £30.
Kindest Regards,
Richard.
liam.mccaffrey
posted on 9/12/09 at 10:36 PM |
MNR were working on one, I took this pic at Total Kit car Live in 06???
Build Blog
Build Photo Album
mangogrooveworkshop
posted on 9/12/09 at 10:40 PM |
martin motorleria made his own
posted on 9/12/09 at 10:45 PM |
liam pictures the raceleda one, which i believe MNR have now stopped making, though i may be wrong.
snakebelly
posted on 10/12/09 at 09:10 AM |
that picture isnt the raceleda one, the raceleda one is a one piece casting that one is fabricated
welderman
posted on 10/12/09 at 10:07 AM |
this is my attempt, does it work ?. i will have to see, lol.
Thank's, Joe
I don't stalk people
SPYDER
posted on 10/12/09 at 10:18 AM |
Hi there. Picture below shows the fabricated upright design on our Phoenix. It is basically made from two intersecting tubes. But there's the
rub. The angles have to be spot on. A jig will almost certainly be required. In your case I guess you would have to mimic sierra geometry so there is
the start point for a jig.
This level of fabrication isn't easy, that's why you don't often see fabricated uprights, particularly DIY ones.
If you do take the project on make sure that you enlist the services of a good welder.
Before you ask, no, we didn't make these ourselves, they came from Stuart Taylor Motorsport, albeit in un-finished form. We had to sort out the
steering arms. They weren't welded by Eldon, either. His welding is loads better!
Geoff & Eldon.
[img][/img]
turbodisplay
posted on 10/12/09 at 10:20 AM |
If you wer to use the 2 intersecting tubes as above, i would get laser cut tube, so it was spot on.
Darren
flak monkey
posted on 10/12/09 at 08:53 PM |
I designed some a while back, but never released the drawings for safety reasons.
For long term safety they ideally need stress relieving.
Plus they are also very dependant on the welders competance.
Sera
http://www.motosera.com
posted on 10/12/09 at 10:34 PM |
IIRC Rortys design used interlocking parts to ensure a decent level of accuracy of the assembled item (though it will still distort after welding I
guess).
