Author: Subject: braking options?
daniel mason
posted on 11/1/10 at 09:48 PM Reply With Quote
braking options?
what other options are there for front brake discs/calipers and rear handbrake calipers as sierra seem quite heavy but others like wilwood seem good quality but expensive.
could honda s2000 brakes be used/modified to fit or are they also quite large? thanks
hicost blade
posted on 11/1/10 at 09:59 PM Reply With Quote
You could try Fiat Coupe 20v turbo Brembo's
http://www.migweb.co.uk/forums/other-mechanical-electrical/397623-fiat-20v-brembo-tigra.html
hicost blade
posted on 11/1/10 at 10:00 PM Reply With Quote
http://cgi.ebay.co.uk/fiat-coupe-20v-turbo-pair-front-brembo-brake-calipers_W0QQitemZ140371845033QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM? hash=item20aed05fa9
daniel mason
posted on 11/1/10 at 10:21 PM Reply With Quote
would a 15" rim be needed with those calipers,and i suppose the discs will not fit?
[Edited on 11/1/10 by daniel mason]
franky
posted on 11/1/10 at 10:47 PM Reply With Quote
how about bmw brakes off an e36.... cheap to buy and 286mm.
daniel mason
posted on 11/1/10 at 10:52 PM Reply With Quote
was un sure what would fit with alloy upright and ford hub? was un sure of wheel size i would need to accomodate caliper?
ideally if i broke an s2000 i would like to fit them but i would imagine discs and calipers are large and heavy! it may be better to sell the s2k brake package (not sure what they are worth) and fit wilwoods with a lighter disc
hicost blade
posted on 11/1/10 at 10:56 PM Reply With Quote
My E36 callipers weigh a ton
ashg
personally i wouldn't bother with the coupe brembo callipers they are huge weigh a tone and are pretty prone to sticking pistons. you will also need a minimum of 16inch wheels with quite a large of offset as they stick out quite far from the discs and hit the wheel spokes oh and you will need 305mm discs 28mm wide which also weigh loads.
how do i know all this? lets just say i have been down that road.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
franky
posted on 11/1/10 at 11:02 PM Reply With Quote
whats a bit of extra weight when you've got a 240bhp car to stop???
GeorgeM
posted on 11/1/10 at 11:03 PM Reply With Quote
Daniel, what about MNR's R16 replacements.
They are light, and work.
GeorgeM
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
ashg
posted on 11/1/10 at 11:04 PM Reply With Quote
personally i would go with wilwoods all the parts and brackets are off the shelf items.
your looking at £250ish for a wilwood kit from rally design. you can prob make that selling the honda items on the bay.
i would only use the honda brakes if i was using the s2000 front uprights
RK
posted on 11/1/10 at 11:35 PM Reply With Quote
MX5s, although they are 4 x 100 studs not 114 like the Fords, which are actually 108 (Thank you!). . The cable handbrake works very well too.
ps My god, I can't know everything!
[Edited on 13/1/10 by RK]
hicost blade
posted on 11/1/10 at 11:41 PM Reply With Quote
^^ Ford PCD is 108mm
hicost blade
posted on 11/1/10 at 11:52 PM Reply With Quote
I wouldn't worry about disks, go to your local motor factors and ask to look through the QR catalogue and select the size, offset PCD you want.
108mm PCD makes and models include
Pug/CitroŽn 4 stud
Audi 80 4 stud
Ford 4 stud.........
The disks do not have to match the original size exactly although thickness is a little more important, they have a range:
http://www.rallydesign.co.uk/pdf/designing_4_pot_brakes.pdf
Saying that, by the time you have messed about the Wilwood option will have seemed cheap!
matt_gsxr
posted on 12/1/10 at 12:07 AM Reply With Quote
Wilwood at the front makes for a very good value and competent package.
The rear is more difficult. People have tried:
Sierra calipers. Popular for all obvious reasons, despised for all the obvious reasons (weight, rubbish handbrake, weight). Use with Escort Mk3 front disks if you want to fit under 13inch wheels.
VW Golf mk4 style (also on Audi's) alloy caliper. Similar geometry to Sierra, but a bit lighter.
Rallydesign VW Golf "equivalent". Not clear to me whether this is the same or slightly different. Some listings on here mention this.
Peugoet 205 (and other models ). Nice and light especially when used with Fiesta 1.1 (i.e. early) disks. Also mentioned on here. Sounds like a light package.
BMW Mini
There are also after market options:
Hi-spec, nice design, reasonably price. UK made. Poor customer service.
Wilwood by Rallydesign. Poor handbrake, not cheap for what it is.
The other problem with disks is fitting it all under 13inch wheels. But if you are going 15 then most of these problems go away.
http://www.brakesint.co.uk/ is a good site for investigating disk sizes and dimensions.
There isn't an easily implemented, cheap, light rear braking solution out there. In my view. I have Sierra because I haven't upgraded yet!
Matt
View User's Profile Visit User's Homepage View All Posts By User U2U Member   matt_gsxr 's Aim
JoaoCaldeira
posted on 12/1/10 at 11:04 AM Reply With Quote
I'm using (bought from MNR) Raceleda uprights + R16 willwoods + R888... incredible stopping power.
In both Algarve International Circuit and Estoril GP Circuit I'm braking in 100 - 90 meters mark... very impressive!!! You have to break really hard, so mass goes to front and wheels won't lock.
Balance bar is set 75% to front (well... al this in dry weather, of course...)
Regards,
Joao
bassett
posted on 12/1/10 at 01:53 PM Reply With Quote
Once there on your really not going to notice the weight especially with the rears id leave them with brackets made to fit the job making it simpler and cheaper to look after. For the front i have the wilwood calipers with MNRs vented and drilled discs although i am sure how easy these get upto temp. The pads however i would avoid the smart pads, many seem to opt for the mintex 1144's which il be trying soon.
daniel mason
posted on 12/1/10 at 06:02 PM Reply With Quote
thanks very much for the info guys!
i am hoping to go with 13" rims, unless its not possible with the calipers!
[Edited on 12/1/10 by daniel mason]
beaver34
posted on 12/1/10 at 06:35 PM Reply With Quote
are the mnr calipers for solid disk i presume?
GeorgeM
posted on 12/1/10 at 07:26 PM Reply With Quote
yes for solid discs, MNR ones are drilled & grooved.
Don't need anything more, they won't get up to temp.
GeorgeM
[Edited on 12-1-10 by GeorgeM]
MNR Racing
essexkitcarclub.com
franky
posted on 12/1/10 at 08:18 PM Reply With Quote
if they don't get up to temp then why have them drilled?
daniel mason
posted on 12/1/10 at 08:43 PM Reply With Quote
i would imagine they get hot when on track!
GeorgeM
posted on 12/1/10 at 09:09 PM Reply With Quote
my point is , you don't need vented discs
GeorgeM
MNR Racing
essexkitcarclub.com
sebastiaan
posted on 20/1/10 at 08:07 PM Reply With Quote
How about sierra drums? Light, cheap and makes you stands out from all the rear-overbraked sevens
