Author: Subject: Astra G clutch replacement anyone done one?
t16turbotone
posted on 26/1/10 at 10:26 AM Reply With Quote
Hi peeps, clutch gone on astra van, mate of mine tells me you have to drop the whole subframe out with steering rack etc etc...anyone know of a quicker method pls? 1.6 8v model x16szr
thanx
tony
ashg
posted on 26/1/10 at 10:55 AM Reply With Quote
yep done 2 now. hang it on the engine crane engine mounts off push engine over seperate gb but leave it in the bay replace clutch put back together. first one i did took about 3hours the second one i did in about 2 hours.
i never understand why people insist on removing the whole gb out of the bay just to change a clutch when in reality you only need to split it just enough to get your hands in.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
t16turbotone
posted on 26/1/10 at 11:19 AM Reply With Quote
thanx ash, will there be enough room to replace hyd slave using your method?
ashg
posted on 26/1/10 at 12:46 PM Reply With Quote
you might get away with it but it will be tight if you remove the drive shafts you might be able to tip it upwards to get at it.
[Edited on 26/1/10 by ashg]
