Printable Version | Send to Friend
Subscribe | Add to Favourites
<<  1    2    3  >>
Author: Subject: Mac Worx RR build thread
20vturbogaz
posted on 5/7/10 at 10:48 PM Reply With Quote
Looking good marra. Is browny on here yet.
Red16
posted on 9/7/10 at 08:26 PM Reply With Quote
Aye Browny's on here, B120WNY is his username.
Red16
posted on 9/7/10 at 08:33 PM Reply With Quote
Been assembling the rear end today
Fitted the brake caliper brackets to the uprights.
Drivers side
Passenger side
Then done a small amount of work to the front end, fitted the arms to the steering rod and secured the rubber boots.
Hoping to get my rear hubs back tomorrow, then the brakes can be fitted.
Red16
posted on 11/7/10 at 08:05 PM Reply With Quote
Small update of the weekends work, nothing spectacular just a spot of painting, also fitted a set of longer wheel studs to suit the Pro Race 1.2 wheels.
The rear hubs are now back from being machined and are painted but not dry, hence the lack of photos.
Red16
posted on 12/7/10 at 09:10 AM Reply With Quote
One pair of machined rear hubs with longer studs fitted and a pair of track rod ends, both been sprayed with black Hammerite Hammered paint.
Red16
posted on 12/7/10 at 07:22 PM Reply With Quote
Rear hubs and brake caliper brackets fitted, driveshaft nuts need to be torqued up once the brakes are operational.
Rear brake discs and calipers fitted and it started to look like this
With my mate, Decka, acting as a temporary wheel nut a wheel was tried on the back, starting to look quite wide now
The side panels were trimmed for the final time, or so i thought, i now think i'll merge the steering rack hole with the front lower wishbone hole, as most people do.
The passenger side front suspension was then built up
Drivers side
Took the nose cone off to fit it in the garage, need to move my vice stand to get the car further back... job for another day
Thanks to Decka for the assistance today, I'm dead happy with the kit, it's really starting to look like a car now
Red16
posted on 13/7/10 at 08:11 PM Reply With Quote
This afternoon i took the suspension off the front of the car and decided to do the final trimming to the side panels
Before
After
All the steering/suspension fitted back to the car again. The washers in the upper wishbone mounting brackets are temporary until i get some bushes knocked up.
I done a quick little job while the side panel was off and fitted the master cylinder.
<<  1    2    3  >>
Connectivity donated by NetrinoUK
All content © 2001-6 LocostBuilders. Reproduction prohibited
