Author: Subject: xflow with bike carbs over revving on idle
Sij
posted on 14/4/10 at 12:50 PM Reply With Quote
As above when started from cold it idles fine at 900-1000rpm but as it warms up it idles at 2000rpm. Then when I blip the throttle it increases to 3000 rpm. When driving its ok but when I let go of the throttle it idle between 2-3000rpm. I have undone the idle screw to the maximum and sprayed carbs cleaner down the trumpets. No joy, Any help would be appreciated.
posted on 14/4/10 at 12:58 PM Reply With Quote
Im wondering if your butterflies aren't returning to the 'off' position as it warms up. Do you have a return spring on the throttle cable, at the carb end?
Alternatively, are you sure everythingis fully off when you close the choke?
GaryM
posted on 14/4/10 at 01:12 PM Reply With Quote
Have you checked that all the throttles (butterflies) are closing completely when you take your foot of the gas?
Sij
posted on 14/4/10 at 01:28 PM Reply With Quote
Yes there is a spring and it does close all the way.
bbwales
posted on 14/4/10 at 01:53 PM Reply With Quote
I had the same with my R1 carbs, only cured it by adjusting the cable so that there was some slack in it, this then allowed the carbs to close fully.
HTH
Bob
Danozeman
posted on 14/4/10 at 02:51 PM Reply With Quote
Are they balanced properly?? How much is the pilot screw unscrewed?
Dan
Sij
posted on 14/4/10 at 02:56 PM Reply With Quote
Originally posted by bbwales
HTH
Bob
I dont think its the cable because when I try to close it with my hand it does not make a difference.
Sij
posted on 14/4/10 at 02:59 PM Reply With Quote
Not sure if they have been balance but the guy I got them from did say that they were balanced.
The Screw is undone all the way.
posted on 15/4/10 at 06:44 PM Reply With Quote
Coming back to this a bit late... when the engine's warmed up, and it's idling too fast, have you tried pushing the quadrant that operates the butterflies? By "quadrant", I mean the disc or whatever that the cable pulls on.
If so, when you push it closed, do the revs drop? If so, then you have a problem with the throttle closing (sticky throttle cable, not enough return spring, etc). If not - then I have no idea!
Fizzer
posted on 17/4/10 at 12:20 AM Reply With Quote
Agree with Dan, get flow meter and balance them, take your time and recheck.
Also check linkages between carbs for looseness or any potential source of variation.
It only take a mild imbalance to cause a very variable idle, sloppy linkages need sorting.
Also, perhaps running rich at idle?
cliftyhanger
posted on 17/4/10 at 06:24 AM Reply With Quote
Air leaks? has the problem just started?
Try spraying carb cleaner or WD40 etc around all the joints, carb/manifold, manifold/head etc, see is you get a change of engine note. How about throttle spindles? Older cars had issues with these, not sure about bike carbs...
BUT I would def start by disconnecting accelerator cable, and loosening all linkages first, check balance like that, all hoses, any blanking plugs/vacuum hoses etc that may be fitted.
Sij
posted on 17/4/10 at 12:31 PM Reply With Quote
Sorted
The butterfly thing the cable pulls on wasn't fully returning back, So i fitted a spring to pull it back sorted.
Thank you very much for the help guys
[Edited on 17/4/10 by Sij]
posted on 17/4/10 at 02:22 PM Reply With Quote
Good result!
(always worth checking the easy things first...)
