Author: Subject: What have I done wrong?
Sprytny
posted on 15/4/10 at 09:03 PM Reply With Quote
I have removed the drum from my drum brakes, but the rubber from the actuator has unsealed itself as can be seen. It is pink in colour. What have I done wrong and how can it be eradicated?
russbost
posted on 15/4/10 at 09:07 PM Reply With Quote
Not a good pic, but if I'm seeing it right just clip the rubber back over the cylinder & gently squeeze the shoes down to push the piston back in enabling you to get the drum back on.
austin man
posted on 15/4/10 at 09:39 PM Reply With Quote
Just looks like its popped the pison out gently squeeze back in and should be okay
blakep82
posted on 15/4/10 at 10:48 PM Reply With Quote
was it like this before you took the drum of though? if not, then push it back in as said, but if it was like that inside the drum, it needs more fixing!
________________________
mad4x4
posted on 16/4/10 at 06:49 AM Reply With Quote
Poor picture but looks like the other end has'nt moved. So all movement has come from one end. Take off the shoes and check that if you push in the piston at one end the other moves out by the same distance. Careful push to quickly and it will pop out the other end.....
If the other end doesn;t move suggest cyclinder is siezed.
Scot's do it better in Kilts.
