Author: Subject: valve clearances
Sprytny
posted on 18/4/10 at 09:40 PM Reply With Quote
valve clearances
Would incorrect valve clearances cause problems with idling, i.e. high idling? My simple logic would suggest this perhaps
speedyxjs
posted on 19/4/10 at 06:11 AM Reply With Quote
Dont think so. It normally just causes a tapping noise. Have you checked your idle control valve? If not, remove, turn ignition on and the valve should fully retract and then settle back into position.
posted on 19/4/10 at 06:27 AM Reply With Quote
how incorect?
if adjusted so the valves never close, you will get poor compression so poor running.
posted on 19/4/10 at 07:28 PM Reply With Quote
If the valve clearances are too tight you will have problems getting the engine to idle , high fuel consumption and lack of power .Not a too fast idle. Over advanced ignition timing or a badly adjusted carb/throttle body would be the first things to check although correct valve clearances are important
