New Topic New Reply
Author: Subject: Are "large head rivets" essential for floor panels?
wood85
posted on 21/4/10 at 07:37 PM Reply With Quote
I've just started building and have found that the 4.8mm blind rivets for my floor are not large head rivets. Will this cause any issues? Isn't the silkaflex doing most of the adhesion bit?
ReMan
posted on 21/4/10 at 07:44 PM Reply With Quote
My guess is they will be fine and the balance of adhesion and sealing is probably 50-50 with the sikaflex.
And of course, Hi and welcome to the forum.
Dont forget to donate
[Edited on 21/4/10 by ReMan]
LBMEFM
posted on 21/4/10 at 07:48 PM Reply With Quote
I agree with Re-Man and welcome to the site from me too.
jacko
posted on 21/4/10 at 08:01 PM Reply With Quote
Big head rivets are cra* the heads come off in time use 3/16 small head rivets
big-vee-twin
posted on 21/4/10 at 08:15 PM Reply With Quote
I used standard pop rivets but they were made from stainless steel have only used large head ones for fixing body panels to spread the load a little bit more on the GRP.
Oh and by the way if your chassis is painted or coated the adhesive is only as strong as the adhesion of the paint/coating to the metal so dont skimp on rivets, I spaced mine at 50mm
[Edited on 21/4/10 by big-vee-twin]
http://www.triangleltd.com
wood85
posted on 21/4/10 at 08:18 PM Reply With Quote
Thanks for the welcome guys and your replies. I feel paranoid at this early stage of the build....
big-vee-twin
posted on 21/4/10 at 08:30 PM Reply With Quote
So was I, I am relativity new only started building in November but you will soon be progressing and enjoying all the trials, tribulations and set backs - welcome by the way.
wood85
posted on 21/4/10 at 08:36 PM Reply With Quote
I see from your signature your an R26 owner as well.... Snap.
hicost blade
posted on 21/4/10 at 10:06 PM Reply With Quote
AD54SB are the rivets to use, I'm using them for everything; sides, tunnel, footwells, floor etc.
[Edited on 21/4/10 by hicost blade]
big-vee-twin
posted on 22/4/10 at 11:06 AM Reply With Quote
Yes, a Liquid Yellow one like the pic
New Topic New Reply
