Sprytny
posted on 23/4/10 at 10:24 PM |
Suspension components
Hi
I know this is probably a really silly question. I have a car that needs to be scrapped. I want to remove the rear struts and front springs. If I
remove the these, will the car still stand or will it simply drop to the floor? I am assuming the later, but I am wondering.
G
tomgregory2000
posted on 23/4/10 at 10:32 PM |
floor droping
Mr G
posted on 23/4/10 at 10:41 PM |
Sierra? The rear will be ok if your only removing the damper as the springs will still be doing their job for moving it,just undamped.
The front springs would be a different kettle of fish though! Once you remove them you would need to replace them with some timber between the bottom
spring platform and top turrent to still be able to move the car.
HTH
G
Y
Sprytny
posted on 23/4/10 at 11:11 PM |
Thanks for your prompt replies.
I was assuming that this would be the case, but I just wanted to be "doubly sure".
