Author: Subject: Bracket dimensions
Brommers
posted on 4/5/10 at 12:28 AM Reply With Quote
Bracket dimensions
OK, confession time - I'm not building a Haynes Roadster. In fact, at the moment I'm building some new suspension arms for my Fury racer <--- but I'm trying to work out if some of the brackets and bits sold by 3GE might help.
If anyone has the dimensions of the SUS2, SUS3 and bush tubes sold by 3GE I'd be very grateful if they could let me know. In particular, I'd be interested in knowing the height of the brackets from their base to the centre of the hole, and the width of the brackets, and the internal diameter of the bush tube.
DB
3GEComponents
posted on 6/5/10 at 01:15 PM Reply With Quote
Hi DB,
The dimension of SUS2 is 34mm, these are for the shock mounts, SUS3's are 44mm for the wishbones. They are 30mm in height from their base to the centre of the hole.
Bush tubes are 33.7mm OD with a wall thickness of 2.6mm giving an internal diameter of 28.5mm.
Hope this helps.
Kind regards
John
