Sprytny
posted on 6/5/10 at 10:32 PM |
Erratic idling...
Hi
I have a deauville 650, and its idling is erratic. What should be my first checks, and how are they performed?
It idles only slightly erratically, perhaps a 50 rpm fluctuation. Would carb cleaning help for example?
Regards
Greg
mookaloid
posted on 6/5/10 at 10:34 PM |
carb balancing would be my first thought
Mark
Dingz
posted on 6/5/10 at 10:44 PM |
I assume its a 2CV, check for air leaks on the engine side of the carb, simplest way is to spray something like carb cleaner/WD40/deodorant/ around
the joints, when running, if the revs increase there is a leak in that area. Otherwise check the carb is clean especially the idle jets.
went on and on.
matt_gsxr
posted on 6/5/10 at 10:45 PM |
what is a deauville 650 is my first thought.
Time for bed
Sprytny
posted on 6/5/10 at 11:48 PM |
A honda deauville is a motorcycle. I will try carb balancing: I had trouble finding the jets initially so I will look again, perhaps inc. a photo here
if I can't still locate them.
Greg
l0rd
posted on 7/5/10 at 06:22 AM |
+1
