New Topic New Reply
Author: Subject: How do you calculate how much a tube will bend?
smart51
posted on 14/6/10 at 02:36 PM Reply With Quote
I have a steel tube supported at both ends. I am placing a weight in the middle. How do I calculate how much it bends?
SeanStone
posted on 14/6/10 at 02:38 PM Reply With Quote
Errm something to do with second moment of area? I can't remember. Deflection of beams was a while back!
austin man
posted on 14/6/10 at 02:46 PM Reply With Quote
there will be many factors length diameter, wall thickness, load it will be carrying
http://www.engineersedge.com/beam_calc_menu.shtml
posted on 14/6/10 at 04:56 PM Reply With Quote
ISTR for simple supports with point load smack in the centre
(W*L^3) / (48*E*I)
Where
W = Load
L = Distance between supports
E = Youngs Modulus for Material
I = second moment of area of cross section of beam.
[Edited on 14/6/10 by britishtrident]
[I] What use our work, Bennet, if we cannot care for those we love? .
dinosaurjuice
posted on 14/6/10 at 05:16 PM Reply With Quote
your after 'beam deflection' equations.
see HERE
Humbug
posted on 14/6/10 at 05:34 PM Reply With Quote
Bend it until it folds, then back a bit
smart51
posted on 14/6/10 at 06:35 PM Reply With Quote
Thank you. My top wishbones will extend inward to push down on inboard dampers. I wanted to know if I needed to reinforce them with a central member in pure compression. They will bend by 73um laden but stationary rising to 3.2mm if the whole vehicle is dropped onto the front wheels at 10g.
Now I need to know how many g they will see in operation. Whilst 0.073mm is nothing, 3mm sounds like a lot.
madteg
posted on 14/6/10 at 07:24 PM Reply With Quote
one and a half times the diameter
smart51
posted on 14/6/10 at 08:44 PM Reply With Quote
I don't follow. 1.5 times the diameter of what is what?
Bob C
posted on 14/6/10 at 09:43 PM Reply With Quote
I always thought you were supposed to stress for 3G.
I think 10G sounds rather a lot - there will be failures all round the car at that level.
Dingz
posted on 14/6/10 at 10:29 PM Reply With Quote
Its the minimum radius you should bend tube, 1.5x tube dia, but it depends on other factors too, if it is supported on a mandrel etc.
Unfortunately its not the answer the questioner wanted tho'
went on and on.
86barettaguy
posted on 21/7/10 at 08:27 PM Reply With Quote
I've seen people state everything from 3G to 5G for pothole incidents. Check with the guys over at eng-tips.com, they might have an answer. Or maybe not.
10G and the whole load on the front wheels seems very excessive.
I would start with 5G and consider the vehicle to not be accelerating or decelerating. I would also compare the results to those for a proven design (like that used by mr Champion for the book) to check whether or not they're reasonable.
View User's Profile E-Mail User View All Posts By User U2U Member   86barettaguy 's ICQ status
Rocket_Rabbit
posted on 19/11/10 at 02:21 AM Reply With Quote
10G would mean a 1.5 ton corner loading.
Your alloy wheel will never take it, never mind your sus arm lugs!
Unless you are planning a Dukes of Hazzard photoshoot, your car will never see 10G unless it's a crash.
Ian-B
posted on 19/11/10 at 07:20 AM Reply With Quote
For info on suspension loads, I've run strain gauges on the race car, the highest loads observed are around 6G vertical, this was only achieved very rarely (in the region 10-20 occurances a season), generally only when the driver had placed the loaded wheel over a very significant kerb. I would expect that for normal road use the pot hole loads would typically be lower, as you are relatively unlikely be hitting a pot hole whilst on limit braking or cornering.
I would be more inerested in the maximium stress rather than deflection for abuse loads. I normally only bother with deflections at normal loads. I abuse load cases extra deflection can be good for reducing shock loads placed on components further up stream, although this is always likely to copromise goodperformance at normal loads.
Regards
Ian
Minicooper
posted on 20/11/10 at 05:07 PM Reply With Quote
Another question for you mechanical engineers out there if I have
80 x 40 x 2.64 rectangular box section this way up [ __ ]
30 o/d x 2.64 round tube 2 off side by side OO
Both 1400mm long supported at each end, point load in middle, same material mild steel
Which is stronger in deflection by what margin?
Hopefully people can work out what I'm after
[Edited on 20/11/10 by Minicooper]
Liam
posted on 20/11/10 at 07:12 PM Reply With Quote
What's your design? The inner end welded to the bush tubes sort of mirroring the outer wishbone? If so you should be more worried about stress on the welds than deflection. Also, ultimate load calcs are all well and good, but it's fatigue over time that will cause a failure. I went for an additional member as you describe - see photo archive. Need to think about the pivot point too as there's a huge load on there.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   Liam 's Aim This User Has MSN Messenger
Horizenjob
posted on 1/1/11 at 06:52 AM Reply With Quote
The wonderment of steel is that that is not the practical case. It is the case for aluminum, wheels are counted as having a load cycle every revolution. So a race car's wheels can be quite light because they don't turn very many times. A street car must use a lower design limit because it rotates it's wheels so many times.
Consider the stresses in connecting rods or valve springs. They cycle their load many, many times. Now it is clearly possible to fatigue a piece of steel but I believe it to be relatively unique in being fatigue resistant. I am not a material specialist by any means, but I think if you stay under the yield limit the fatigue life is indefinite? Something to do with the carbon in the steel... I hope someone chimes in...
novacaine
posted on 2/1/11 at 09:37 PM Reply With Quote
you are right, so long as you stay under the fatigue limit for steel there will be no failure by fatigue (theoretically)
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
novacaine
posted on 2/1/11 at 09:50 PM Reply With Quote
the round tubes will be stronger in the current loading conditions,
the 2nd moment of area for and individual tube is 1.96x10e-7 compared to the 1.66x10e-7 for the square tube
meaning if you use two round tubes under the same loading conditions it will be approx 2.5 times as strong as the rectangular beam
however
using the rectangular bar "portrait" (as opposed to the landscape orientation it currently is in) it would be significantly better than it currently is giving a 2nd moment of area of 5.0x10e7 meaning it would be stronger than the twin tube setup
the loading conditions dont matter so long as they are the same for both round and rectangular, the only important bit is the 2nd moment of area
hope this is of help to you
courtesy of a 2nd year mechanical engineering student, so no guarantees for its accuracy, even though i am sitting an exam on it a week tomorrow
********edit to correct an error in the calculations********
[Edited on 2/1/11 by novacaine]
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
indykid
posted on 3/1/11 at 12:52 AM Reply With Quote
however
probably worth having a look back over your calculations for the round tube there. intuitively, the rectangular tube has far better material distribution for bending loads.
my calcs agree with your answer for the square, but for the round, i only get 2.14x10^-8, so 4.3x10^-8 for both tubes together, neglecting any welds. the rectangular tube wins by a factor of 3.87
what formula did you use? Ixx=pi(do^4-di^4)/64? less material in a less favourable distribution can't possibly yield a higher second moment of area.
courtesy of a 5th year MEng Motorsport student, but still, don't take my word for it
joking aside, good luck with the revision. i've got an FEA and vibration exam on the 21st. i hate exams!
me? ambivalent? well, yes and no
New Topic New Reply
