Author: Subject: MAC#1 WHEEL OFF SET (HELP)
john77cars
posted on 25/7/10 at 07:54 PM Reply With Quote
iv got a mac#1 with 13" team dinamic wheels suplied by mac#1 themselfs,so my plan is too get some slick tyres and another set of 13" wheels,the only thing is,iv tryed a few diffrent sets of wheel and non of them fit,the of sets are not right,can anyone recomend any alloy wheel that will fit (cheap) thank you.
bi22le
posted on 25/7/10 at 10:22 PM Reply With Quote
mac 1 are sierra donors as far as i knew. So anything for a sierra will fit it.
Please read my ring story:
Red16
posted on 26/7/10 at 04:55 PM Reply With Quote
If i remember correctly the offset is ET30.
Flamez
posted on 4/8/10 at 11:22 AM Reply With Quote
Don't think sierra's had 13" wheels
my build mac1motorsports
grusks2
posted on 4/8/10 at 06:42 PM Reply With Quote
14" & 15" on sierra's
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
bonesetter
posted on 8/8/10 at 08:10 PM Reply With Quote
OP - Did you get the answer you needed?
I am in the same boat trying to source a second set of rims...
john77cars
posted on 9/8/10 at 08:56 AM Reply With Quote
it seems the only way is to buy a set of new wheels from mac#1,iv tryed some other 13" wheels and none of them clear the calipers.
bonesetter
posted on 9/8/10 at 06:40 PM Reply With Quote
Jeeszz! £620 a set...!
Isn't there a cheaper option of going to a larger diameter and getting around the caliper clearance?
Flamez
posted on 10/8/10 at 10:04 AM Reply With Quote
I believe you could use 14" wheels with a lower aspect ratio tyre.
see here
so currently you are probably running 185/60 13 on the front.
You may be able to change this to 185/55 14 leaving your overall diameter and height roughly the same.
Go and talk to your local tyre dealer they are usually helpful especially if you pick an indie who is interested in racing etc and most are..
hth.
