Author: Subject: yamaha r1 2008 problem
shorts
posted on 23/10/10 at 01:20 PM Reply With Quote
i have got my motor fired up but it will only fire up for a second then cuts out, if you hold the start button down it will run all day it seems. has anyone got any ideas what it could be ??
cheers
Dave
barbarianbeast
posted on 23/10/10 at 02:51 PM Reply With Quote
never had that problem with my 2008 r1, could be a few different things. have you checked the obvious stuff like the tilt and kill switches. this web page helped when I did mine. I know its the older engine but makes a handy check list.
http://www.robcollingridge.com/kitcar/design/engine/electrics.html
and just make sure all the earth points are sound. they always cause weird problems
austin man
posted on 23/10/10 at 03:02 PM Reply With Quote
is the supply to the coil correct ie youve have just put a supply via the starter switch have you ? I would think it needs an ignition switched live to it
shorts
posted on 24/10/10 at 01:18 PM Reply With Quote
r1 probs
Hi yes i have checked all the tilt and other cut outs all ok, I'm now wandering if its the fuel pump relay. but stilll open to ideas of what it maybe.
Dave
