Author: Subject: R1 4c8 (08) Mounting Position
Kev99
posted on 12/11/10 at 05:04 PM Reply With Quote
What position do I sit the engine at as is with the sump line horizontal
Or is it the Yamaha on the engine casing horizontal
position
position
jossey
posted on 12/11/10 at 05:10 PM Reply With Quote
Matt a junior builder was mentioning the same thing.
http://locostbuilders.co.uk/viewthread.php?tid=145869
ive been advise that if the yamaha logo is straight your ok.
dave
ps good luck :O)
adithorp
posted on 12/11/10 at 05:11 PM Reply With Quote
Don't know about the 08, but the earlier ones sit in the bike with the base of the sump level . However in many cars they have been mounted at an angle in order to get them under the bonnet. Mine is like that with the sump gasket almost level. 10000 hard miles and no problems. A few of the RGB cars are like that as well I believe.
http://jpsc.org.uk/forum/
locoR1
posted on 12/11/10 at 05:16 PM Reply With Quote
If i had to guess i would say the Yamaha horizontal. assuming with the sump flat on the floor the logo is horizontal?
As you know my 4xv has the sump bottom level not the sump joint line. don't know if the 4C8 is the same though!
Got an exhaust manifold yet?????
Check out my CB500T Cafe Racer build diary
loggyboy
posted on 12/11/10 at 05:18 PM Reply With Quote
Considering bike engines are designed to work in an environment where they are thrown from one side to the other by more 45 degrees each way I cant see 5-10 degrees making a huge difference.
(Just an uneducated observation)
Kev99
posted on 12/11/10 at 05:30 PM Reply With Quote
Pick exhaust manifold up tomorrow LocoR1....
think it will be the Yamaha horizontal as sump will sit flat as well
Thanks all
Davey D
posted on 12/11/10 at 05:54 PM Reply With Quote
On my 5vy (which i believe is very similar to the 4c8) the sump bottom is parallel to the floor, which will also bring the yamaha logo level too
