New Topic New Reply
Author: Subject: engine for minio kitcar?
speedy123
posted on 18/11/10 at 11:13 PM Reply With Quote
right guys, i wanna build my son a kit car but need some help choosing the basis of which to work off, grasshopper? cobra? or totrod?
but What engine would i use in one of those,
would it be like a lawnmower engine? or??????
thanks guys
Duncan Mould
posted on 18/11/10 at 11:19 PM Reply With Quote
Mobility scooter
bbwales
posted on 18/11/10 at 11:33 PM Reply With Quote
If you get a petrol engine off a cylinder mower you will have a centrifugal clutch which you can couple to one of the rear wheels, saves having a diff and will save on tyre wear. You can have an axle which is coupled to one wheel and the drive wheel sleeved over the top of the axle. If you go for the grasshopper you could make a chassis to take the engine and then bolt on the body.
Regards
Bob
owelly
posted on 18/11/10 at 11:53 PM Reply With Quote
I bought a go-ped from an autojumble for £12. The whole engine and transmission can be used. It also has a centrifugal clutch.
http://www.ppcmag.co.uk
steve m
posted on 19/11/10 at 01:25 AM Reply With Quote
I used two cheap electic drills on my grandsons landrover
was powerfull enough for me to drive it
UncleFista
posted on 19/11/10 at 02:19 AM Reply With Quote
Dunno if this is still available.
500cc, twist and go, with clocks, only 112miles for £180.
My son's 6'4"
[Edited on 19/11/10 by UncleFista]
Tony Bond / UncleFista
blakep82
posted on 19/11/10 at 05:03 AM Reply With Quote
makro sell pressure washers with a 4hp engine (?) same as the honda go kart type, but the whole pressure washer is cheaper than the cost of the engine from most places. might be worth a look?
________________________
iceman26
posted on 19/11/10 at 07:57 PM Reply With Quote
i have a gx 390 13hp clone engine for sale if you need a engine
New Topic New Reply
