New Topic New Reply
Author: Subject: Removing paint overspray off powder coat?
Oliver Jetson
posted on 24/1/11 at 08:45 PM Reply With Quote
Can car paint that has ended up as overspray be removed from a powder coated item without destroying the powder coat?
Steve Hignett
posted on 24/1/11 at 08:51 PM Reply With Quote
Not that I'm recommending you do this, but if it were mine, I would give it a very swift wipe over with a rag and a bit of acetone...
The acetone will soften the powdercoat if loeft on for any time, but like I said, it's what I'd do!
MakeEverything
posted on 24/1/11 at 08:59 PM Reply With Quote
A green scourer, then t-cut the powdercoat afterwards,
Kindest Regards,
Richard.
blakep82
posted on 24/1/11 at 09:03 PM Reply With Quote
depends how much 'overspray' there is. if its real overspray, ie a very thin dusting, bit of wet and dry paper, wet.
________________________
Oliver Jetson
posted on 24/1/11 at 09:04 PM Reply With Quote
Will it soften the dried paint faster than the powdercoat giving time to scrub the paint off?
gazzarose
posted on 24/1/11 at 09:11 PM Reply With Quote
What kind of car paint was it?if its was celulose from a rattle can then celulose thinners will remove it and it doesn't damage most plastics so should be fine on powdercoat.if its 2 pac then it won't work.
Gareth
Oliver Jetson
posted on 24/1/11 at 09:12 PM Reply With Quote
I just read a clay bar might work?
avagolen
posted on 24/1/11 at 09:33 PM Reply With Quote
I used T-cut and turtle wax polish - (plus a little elbow grease)
Nice smooth slippery finish.
Len.
New Topic New Reply
