Author: Subject: 1300 crossflow carb choice?
goodguydrew
posted on 2/2/11 at 11:48 PM Reply With Quote
What carb would people recommend I use for this engine.
I had considered twin SUs (who's done it?)
A single webber/delorto side draught
A down draught (thought I would prefer not to have it sticking out the top of the bonnet)
Anyone got a carb/manifold for sale?
Cheers.
pekwah1
posted on 3/2/11 at 12:52 AM Reply With Quote
on this note, can you use twin 40's or is this a bit overkill?
skodaman
posted on 3/2/11 at 02:39 AM Reply With Quote
Twin choke webber dgv with ITG foam filter. Only the foam bit sticks up from bonnet so should be fine for IVA.
Skodaman
FASTdan
posted on 3/2/11 at 07:36 AM Reply With Quote
36-38mm bike carbs?
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
atspeed racing
posted on 3/2/11 at 09:15 AM Reply With Quote
A modification that I did many years ago was to get a standard twin choke Ford manifold and put the SU straight on the end, machining and welding a flange on the end.
This was on a 1300 X/Flow. It was a good job and run really well. Infact Ford did investigate and tested using the SU in the 80's, but used that horrible single choke 'V V' thing instead.
rayward
posted on 3/2/11 at 10:50 AM Reply With Quote
R6 5eb carbs.............
hth
Ray
goodguydrew
posted on 3/2/11 at 08:54 PM Reply With Quote
I missed one of these on eBay. Does anyone here have one to sell?
FORD CROSSFLOW ALLOY INLET MANIFOLD. MADE BY C.T. (CONVERSION TUNING) TO SUIT TWIN HS4 SU CARBS.
Cheers.
Mike Wood
posted on 17/5/23 at 04:40 AM Reply With Quote
I know this is a long shot, but you don’t happen to still have this inlet manifold for an SU carb that you made for a 1300 Crossflow please? I am looking for one for my 1300cc Locost project.
Many thanks
Mike
