Author: Subject: Modern light engines for longitudinal use?
cloudy
posted on 7/4/11 at 12:19 PM Reply With Quote
Does anyone know any good donor sources of modern engines/gearboxes of engines suitable for mid engined longitudinal fitting? I'm after something lighter than the traditional chevy imports - around the 300hp mark...
James
www.warnercars.com
SeaBass
posted on 7/4/11 at 12:28 PM Reply With Quote
1uzfe
liam.mccaffrey
posted on 7/4/11 at 12:37 PM Reply With Quote
plenty of engines spring to mind if you can sort the gearbox.
Saab 2.3, Volvo T5,
Porsche with transaxle maybe?
[Edited on 7/4/11 by liam.mccaffrey]
Build Blog
Build Photo Album
posted on 7/4/11 at 12:53 PM Reply With Quote
Surely something from Audi would fit the bill - something from a model with longitudinal engine installation and a FWD only transaxle would do it and there's certainly engines capable of the +300bhp figure.
Some examples...
[Edited on 7/4/11 by nick205]
Miks15
posted on 7/4/11 at 12:54 PM Reply With Quote
Planning a new project James?
cloudy
posted on 7/4/11 at 12:58 PM Reply With Quote
Might be
www.warnercars.com
cloudy
posted on 7/4/11 at 01:00 PM Reply With Quote
Forgot to add a key point! I need to be able to source a sequential box for it... Anything available for the audi's? DSG box I suppose?
James
www.warnercars.com
MK9R
posted on 7/4/11 at 01:05 PM Reply With Quote
Yeah a DSG VAG set up would be ideal!!! Highly tuneable, you could even go for a diesel
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 7/4/11 at 01:07 PM Reply With Quote
James
Not sure if there's a longitudinal FWD transaxle with DSG, but as DSG seems to be an option on most Audis (and other VAG cars) I can't see why there wouldn't be. Might make for interesting electronics getting everything to work properly once ripped out of a donor car. More and more components are coded to each other and the car these days with multiple ECUs and bus type wiring systems
posted on 7/4/11 at 01:09 PM Reply With Quote
300 diesel BHP and associated torque would make it interesting
cloudy
posted on 7/4/11 at 01:13 PM Reply With Quote
Yes the engine could be run on MS, but the DSG could be tricky!
My list so far:
RST-V8 - Cost?
1uzfe - Don't know much about this engine...
Audi RS4 V8 - Looks like a good option...
James
www.warnercars.com
meany
posted on 7/4/11 at 04:42 PM Reply With Quote
I know the Subaru 4WD box has been modded to use that way,
the flat4 or the flat6 engine could be used.
nz_climber
posted on 8/4/11 at 10:15 PM Reply With Quote
From Toyota v8 1uz-fe or v6 2gr-fe
Also LS series engines from chev (a lot lighter than the older cast iron small blocks)
Would probably have to decide on a gearbox first and work back from there, but adapter plates can be made for any engine.
http://aarons7.wordpress.com
Badger_McLetcher
posted on 9/4/11 at 12:34 AM Reply With Quote
The 4 litre 1uz-fe is a very good engine but doesn't match up directly to any manual gearbox. It needs an adapter plate and a custom flywheel/clutch assembly.
Power wise it's about 288hp from stock, 500 hp is possible with no internal modifications and forced induction. Above that depends on the year of the engine- the pre 95 engines only need to have new pistons and they can make 1000hp (again with forced induction). The head of the 1uz doesn't breathe very well, so is not so good for NA applications, however it is mental for FI. It has a forged crankshaft, 6 bolt main bearings and has been known to make 400,000 miles.
This is all from a hazey and slightly cidery memory, so please excuse any inaccuracies! A good place for more on this engine is http://www.lextreme.com/forums/
Oh it's also cheap and light. Which is good
I should also point out it is bulky though- effectively 800mm square without gearbox.
[Edited on 9/4/11 by Badger_McLetcher]
If disfunction is a function, then I must be some kind of genius.
