Author: Subject: Ford / EPC wirring connectors ?
mcerd1
posted on 11/4/11 at 12:23 PM Reply With Quote
following on from my last thread - I turns out you can get the connectors new from ford for a couple of £
only problem is they don't come with the terminals and we couldn't find them on the parts system anywhere
I looks like these are a type made by 'EPC' ? but there are loads and loads of different versions
its very similar to one for a duratec crank sensor (but pins etc are turned 90 deg)
anyone got any idea where to get these connectors ??
the plug is ford #: 97BG-14A464-SBA if that helps
Plug
Plug
cheers
-Robert
posted on 11/4/11 at 01:11 PM Reply With Quote
http://www.yazaki-europe.com/
I used to work for Yazaki, loom suppliers to Nissan. Go to the component catalogue and find what you need then click the 'order a sample' where you can get all the components for nowt. Best to order in multiples of 10. They are sent out free every Wednesday from the warehouse in Belgium.
Nice locost way to get any type of connector for your build
mcerd1
posted on 11/4/11 at 02:56 PM Reply With Quote
^^ thanks, but it looks like they don't do the ones I need (still good to know though)
I need one like that as I'm pluging onto the back of an existing light unit
if I give up I'll bucher it and 'make it work', but I've got the plug now so I only need the terminals to finish the job properly....
