Author: Subject: Busa help,
Jon Ison
posted on 25/4/11 at 03:32 PM Reply With Quote
Busa help,
Not mine but a friend with a 2000 bike.
Not seen the problem just spoken over the phone, starts, bike revs immediately to 7k dont know if it wants to rev further tells me he hits kill switch before it does, butterflies fully closed, any ideas ?
As to be getting air from somewhere ?
TPS faulty ?
Ideas please.........
MakeEverything
posted on 25/4/11 at 04:57 PM Reply With Quote
Idle control valve U/S (if they have them)?
Kindest Regards,
Richard.
mad-butcher
posted on 25/4/11 at 07:51 PM Reply With Quote
Always found it helps to try and backtrack
Has it just started doing it on it's own or
Has he been playing with anything. if so what
tony
Frosty
posted on 26/4/11 at 08:44 PM Reply With Quote
Check all vacuum hoses are on as they should be, and then take a look at the idle screw which is right next to the throttle cable attachment to the throttle bodies. Back this right off and see if it changes the idle. Can't think what else it could be. It has to be air getting in from somewhere.
I think there is a cold start cable somewhere too. Check this is as it should be.
Windscreen Wipers
Need windscreen wipers for your car? Order from a friendly kit car owner.
Don't pay a garage to do them. You built a car for God's sake - I'm sure you can fit your own wipers!
richard thomas
posted on 27/4/11 at 03:51 AM Reply With Quote
Seems to be revving really high if the throttle butterflies are closed....must be air entering somewhere...there is a cold start lever on the bodies, this could be intefering....engine needs fuel to rev that high....
sucksqueezebangblow
posted on 30/4/11 at 08:15 AM Reply With Quote
If it is like my '99 Busa there is an idle adjuster knob. Could be that some joker has wound it all the way up?
