Author: Subject: ebay: MX5-based Cobra...
Humbug
posted on 6/5/11 at 07:01 PM Reply With Quote
... "with no SVA/IVA"? Sounds too good to be true - can it really be just a rebody of the external panels, with no changes to the monocoque?
on the bay Ac Cobra replica based on Mazda MX5 rolling project | eBay UK
StevieB
posted on 6/5/11 at 07:12 PM Reply With Quote
It looks fairly clear that parts have been welded onto the monocoque.
If you can't unbolt and lift away the body and any subframes, leaving the monocoque as per the original design then it's off to IVA.
Nice looking project though - wonder if it's home built or a kit.
marcjagman
posted on 6/5/11 at 07:43 PM Reply With Quote
Was reading in CKC about a company who does a similar type of thing for a shportened Mondeo monocoque and no IVA for that either, which seems strange as I understand no VIC or IVA if the mono has not been drastically altered or had anything taken away, so the MX5 conversion should be fine.
stevebubs
posted on 6/5/11 at 08:17 PM Reply With Quote
If it's shortened then it should go through IVA...
Danozeman
posted on 6/5/11 at 08:43 PM Reply With Quote
MMmmm a cobra has the same wheel base as an MX5??
Dan
mookaloid
posted on 6/5/11 at 08:55 PM Reply With Quote
I quite like that
tegwin
posted on 6/5/11 at 09:55 PM Reply With Quote
I also really like that.. but its one of those projects that will either be really well engineered and thought through, or, under that shiny body, will be a mass of bodged scrap requiring expensive rebuilding to complete..
If I lived closer I would go look.. could make a really nice car....
www.verticalhorizonsmedia.tv
dirth
posted on 6/5/11 at 10:02 PM Reply With Quote
was that not ex- Robin Hood's Richard Stewart?
If you chop away the outer,doesn't that lead you on the Banham type problems regarding SVA/IVA
StevieB
posted on 6/5/11 at 10:11 PM Reply With Quote
I think the same applies for adding more to the chassis as well as taking bits away - I was looking into (and still am) building a Sammio Spyder and they have similar issues. The way round it is to prove that any structure you add is only to hold the bodywork in place and if unbolted will lift away leaving the original chassis intact.
The Sammio uses the Herald chassis, which isn't a monocoque like the MX5, so as soon as you replace anyting more than body panels on the Mazda, you've altered the chassis and IVA is required.
That's my understanding of it, anyway (as much as I am ever likely to understand about the IVA pedantry )
iank
posted on 7/5/11 at 11:35 AM Reply With Quote
Yes
Anonymous
stevegough
posted on 7/5/11 at 11:54 AM Reply With Quote
The 'original chassis' of the MX5 consists of the subframes and the monocoque body. Now, if you take away the bodyshell and replace it with another completely different one, even if the dimensions are exactly the same you are substantially altering the original chassis, there is no getting away from that.
Absolutely no doubt this project needs an IVA.
Having said that, it is quite a bonny looking project - it is certainly much nicer than the Exocet which is a similar set up.
But, a Cobra replica MUST have a V8, surely?
All in my humble opinion, of course.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
dirth
posted on 7/5/11 at 07:37 PM Reply With Quote
The seller make the comment on a V12 will fit,
In the states there are MX5 / Miata's with 5.0Liter Ford engines, thats a fair bit lighter than any V12, but the axle gets binned for a 8.8 Ford axle
There is also the mention of the Engine in a different position.
Anyway it's cheap enough to compensate, for any problems
