Author: Subject: ally panels what thickness?
davo
posted on 15/6/11 at 08:58 PM Reply With Quote
just started building an aries
i'm sure this will be the first of many questions
as title says what thickness ally would you all recommend for the tunnels,rear bulkhead & passenger end footwell?
cheers davo
Davegtst
posted on 15/6/11 at 09:31 PM Reply With Quote
Pretty sure mine are about 1mm thick.
MsD
posted on 15/6/11 at 09:33 PM Reply With Quote
Mine are 1.3mm all over, I think builders tend to have slightly thicker floor's to stop the bending/twanging effect!
steve m
posted on 16/6/11 at 07:24 AM Reply With Quote
I used 2 mm all over
Daddylonglegs
posted on 16/6/11 at 08:00 AM Reply With Quote
I've got a 2mm floor, 1.5mm tunnel sides and 1mm everywhere else. No particular reason for the different thickness for tunnel and sides, just what I had available.
2cv
I would suggest that you use a tough alloy for the floor and bulkheads. If you use aluminium grade NS4 18 gauge 1.2mm will be sufficient.
For any panels that need forming such as the bonnet transmission tunnel etc pure aluminium in 18 gauge 1.2mm will do the job. I personally would not go any thinner for body panels.
Angel Acevedo
posted on 16/6/11 at 01:49 PM Reply With Quote
I´d say depends on what you want.
Lighter gauges equal less weight and relative ease of fabrication. E.G. 1 mm
Thicker ones 2 mm, 2.4, Gives more strength and oil canning resistance at the expense of being heavier and a little bit more difficult to shape.
1.6 mm has the Best of both worlds
HTH.
AA
davo
posted on 16/6/11 at 07:45 PM Reply With Quote
thank you all for your speedy replies
hicost blade
posted on 16/6/11 at 08:44 PM Reply With Quote
I used 18 gauge/1.2mm NS4 throughout, the floor was nice and stiff, NS4 is half hard aluminium, this specification is important
Just make sure you use cleco clamps to get it nice and taught
http://www.lasaero.com/site/products/article?id=O0273HUC5&from=search
I used sealed AD54SB rivets to keep the chassis sealed from water ingress
http://www.rivetwise.co.uk/productrange/rivetdetails.asp?partNo=AD54SB
