Author: Subject: Steering wheel too close to legs
sooty
posted on 18/6/11 at 06:31 PM Reply With Quote
I've recently got a Striker II and being tall I have a problem with the steering wheel in the way of my legs when driving.
So I either need to bring the wheel closer or raise the wheel column away from my legs.
I think as to bring the wheel closer, I could modify the first steering shaft attached to the rack with its knuckles each end by lengthening, or I could fit a Boss but it may not bring it out enough.
Or I could raise the column angle away from my legs by modifying the dash and column brackets etc.
Any comments please or has anyone already done theirs for the same reason.
pekwah1
posted on 18/6/11 at 06:36 PM Reply With Quote
you can get steering wheel spacers, would probably sort it out...
give it a google.....
daniel mason
posted on 18/6/11 at 06:37 PM Reply With Quote
what about a smaller diamiter steering wheel?
trextr7monkey
posted on 18/6/11 at 07:10 PM Reply With Quote
We have had this a few times and the cure has always been thinner seats, D shaped Momo type wheel, or to adjust the angle of the coloumn if possible on the vehicle concerned. Other optionis to lengthen the column by turning down a sleeve/ boss to fit the wheel to.
hth
Mike
Frosty
posted on 18/6/11 at 09:46 PM Reply With Quote
Which steering wheel do you have? There's a guy who makes up aluminum steering wheel spacers on the Westfield forum. Any length for about £20.
I had exactly the same problem, and I now love my driving position since buying one. I can put you in touch if you need me to.
Windscreen Wipers
Need windscreen wipers for your car? Order from a friendly kit car owner.
Don't pay a garage to do them. You built a car for God's sake - I'm sure you can fit your own wipers!
posted on 18/6/11 at 10:05 PM Reply With Quote
As others have said... your choice of steering wheel will make a heck of a difference! Size and shape!
It's Evolution Baby!
