Author: Subject: Grinding at the n/s rear when turning right?
Steve Lovelock
posted on 21/6/11 at 09:06 PM Reply With Quote
So I get this grinding on a hard right whilst on a shopping trip at Stoneleigh and forget about it. Then whilst on a shopping trip at Newark I get the same experience. Now I have been on several trips in-between in London and had no problems. I have driven it pretty had in the first three gears on those outings and had no issues. So I take the back wheel off and can't find a thing wrong. No marks anywhere and all relevent items tight and grime free.
I have no idea what to do next and I'm hoping to do the Debden sprint in a few weeks time.
I should say that it comprises of an XR4x4 LSD, disk brakes, push in driveshaft, Gaz shocks as set professionally, standard Luego (Locost) wishbones and 45/195 15" shod Team Pro 1.2's.
Any ideas?
....and preferably cheap and easy.
fazerruss
posted on 21/6/11 at 09:49 PM Reply With Quote
sounds like left side wheel bearing to me
"if assholes could fly this place would be an airport"
HowardB
posted on 22/6/11 at 05:44 AM Reply With Quote
+1,
find a large empty space and go round in circles (both directions) with a passenger willing enough to transfer the his/her weight about,....
Howard
Macbeast
posted on 22/6/11 at 07:32 AM Reply With Quote
Steve.
I'm in Hornsey. If you need a passenger for the above, i'd be happy to try to help
John
tomgregory2000
posted on 22/6/11 at 07:58 AM Reply With Quote
What about the hand brake cable catching on the inside of the rim and making that noise?
Guess how i know
Steve Lovelock
posted on 22/6/11 at 08:51 PM Reply With Quote
I could understand the bearing causing the noise, but can't understand why doesn't it happen on the straight?
Definitely not the brake cable though.
HowardB
posted on 22/6/11 at 08:56 PM Reply With Quote
leave it long enough and it will happen in a straight line, guess how I know??
Howard
posted on 23/6/11 at 06:32 PM Reply With Quote
Turning right will load up the left hand side of the car but may not be the rear wheel bearing, Sierra wheel bearings are normally very reliable front or rear
ReMan
posted on 23/6/11 at 07:42 PM Reply With Quote
Sticky caliper will let the pads drag slightly , exagerated with the wheel sideways loaded
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Steve Lovelock
posted on 12/9/11 at 08:09 PM Reply With Quote
Well I changed the wheel bearing and I still have the same problem.
To repeat, it only happens when I am turning right at reasonable speed to ensure that the suspension is loaded. I have double checked all the wishbone/shock bolts and all tight. Absolutely no visible marks anywhere so unlikely to be rubbing.
The noise is difficult to describe with my limited vocabulary but it is a rough knocking that is at quite a high frequency and only occurs when the car is rolled over on the suspension.
Any ideas again?
Steve Lovelock
posted on 3/3/12 at 07:03 PM Reply With Quote
BTTT
I am hoping to get the car MOT'd and entered for a few sprints soon and I have not solved this knocking / grinding issue. I have replaced the wheel bearing and there is definitely no rubbing on cables etc. Any ideas warmly received.
bonzoronnie
posted on 3/3/12 at 07:26 PM Reply With Quote
Might be worth checking the CV joints on that side.
MkIndy7
posted on 3/3/12 at 09:02 PM Reply With Quote
This is going to sound a really random suggestion.. But check your alternator cooling fan if it has one isin't catching a chassis rail,
ours was doing this once and I'd sworn blind the noise was coming from the back.
