Author: Subject: Tunnel Trim Fixing??
Dick Axtell
posted on 18/8/11 at 02:57 PM Reply With Quote
FAO all those who have successfully fitted the ally trim to their trans-tunnel top.
What did you use to fix the trim? I've seen a couple of examples where dome-headed screws were used, (I'd prefer c/sunk, for lower profile). I reckon some other examples were "glued" on, as there were no mechanical fixings showing.
Please, which is recommended?
Daddylonglegs
posted on 18/8/11 at 03:09 PM Reply With Quote
I shall watch this with interest. That is one of the last jobs I have to do, and I did think of using those trim clips that are used for interior trim panels on most cars but not sure if they would be good enough.
JB
ReMan
posted on 18/8/11 at 03:11 PM Reply With Quote
I screwed as mentioned with ss flanged caps
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Yorkie
posted on 18/8/11 at 04:22 PM Reply With Quote
Fitted mine through the side with 4mm countersunk pins.
karlak
posted on 18/8/11 at 04:37 PM Reply With Quote
Where are you guys getting your "ally" trim from ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Dick Axtell
posted on 18/8/11 at 04:45 PM Reply With Quote
Thanks for the illustrations, (ReMan & Yorkie), that's very useful.
StevieB
posted on 18/8/11 at 05:17 PM Reply With Quote
I trimmed the whole top panel with textured vinyl and used velcro (with strong adhesive) to fix it to the tunnel top.
myke pocock
posted on 18/8/11 at 07:08 PM Reply With Quote
Mine was done in a different way. Alloy covered with vinyl for the top, screwed on using raised head stainless steel screws and stainless steel screw cups going into nutserts in the tube. The side panels of the tunnel are expanded PVC (I think) as used by signmakers for temporary signs again screwed on. This is about 5 mm thick and available in 8' x 4' sheets.
