Author: Subject: Digi dash
Nurburg2006
posted on 31/8/11 at 07:09 PM Reply With Quote
Digi dash
Hello all I have a problem with my digi dash (acewell 3251) I can't set the speedo I am running 185 60 13 anyone no what it should be? The magnet is on the wheel any help would be great. Cheers in advance
gavin174
posted on 31/8/11 at 07:15 PM Reply With Quote
send Russ Bost a message
I am sure he can sort you out
couch22k
posted on 1/9/11 at 08:18 AM Reply With Quote
Jack the car up and measure the circumference of the tyre with a flexible tape and put the length you get in mm (I think) into the dash. Should'nt be far off at that.
If you need a manual try here
Hope this helps.
posted on 1/9/11 at 09:19 AM Reply With Quote
I plugged the sat nav in and tuned the number setting till it read just 1mph over.
