Author: Subject: Laser cutting?
posted on 20/9/11 at 09:11 AM Reply With Quote
Laser cutting?
I know that there are many and various skills on this forum, so here's a non-car question:
I want a few complex shapes cut from good-quality plywood, between 3mm and 5mm thick (or maybe 3mm GRP board).
Octo frame
Octo frame
As the picture shows, the basic outline is the shape of 2 squares on top of each other, with one rotated 45 degrees.
The size of each 'square' is near-enough 4 inches.
All of the holes are 3mm dia. apart from the big one in the middle.
I'd need a total of 6 of these shapes cut out.
I have a DWG file for this shape.
This is what it looks like (a used and battered example!):
Basically, the questions are:
Is it feasible to get this shape laser-cut?
How much is it going to cost me for 6 of them?
Ta,
[Edited on 20/9/11 by David Jenkins]
The older I get, the better I was...
Bob C
posted on 20/9/11 at 09:19 AM Reply With Quote
I've had lots of steel & ally cut by my local laser cutting place. Those shapes would be about 10 each in 2mm mild steel.
The "tech suite" in a local school that I help has a laser profiler which does 3mm ply - try asking a school (if you can)
melly-g
posted on 20/9/11 at 09:34 AM Reply With Quote
There's a company near where I work that laser cuts plywood, Info below.
Farr Formes
Bryggen Road, King's Lynn, Norfolk PE30 2HZ
01553 762705
Don't know How much or if they will do it! Best to just give them a call.
HowardB
posted on 20/9/11 at 10:43 AM Reply With Quote
parts for a model waterwheel?
or a clock?
Howard
mcerd1
posted on 20/9/11 at 10:44 AM Reply With Quote
how about getting andyw7de to cut that out for you on his waterjet machine ?
ChrisW
posted on 20/9/11 at 10:46 AM Reply With Quote
I've got a mate with a laser cutter that can do small stuff like that. I'll show him this thread, see if he can help, and if so put you in touch.
Cheers, Chris
Current projects: '87 XR2 full restoration, MG ZS 2.0 Turbo conversion, fitting a supercharger to my V6'd MR2......... and a petrol-powered Dodgem!
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
ashg
posted on 20/9/11 at 10:58 AM Reply With Quote
whats wrong with a cnc router? less expensive and much more common.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
balidey
posted on 20/9/11 at 12:44 PM Reply With Quote
Not many laser people will like cutting wood. Yes its possible, but most will turn you away.
If it needs doing cheaply, the way I would do it is print off the template, stick it onto the ply and then get a dremel or similar and cut round by hand. Yes may take a while, but think of the sense of achievement you will get
Dutch bears have terrible skin due to their clogged paws
posted on 20/9/11 at 04:27 PM Reply With Quote
Problem solved - found a local chap who will do it for me...
29 for 6 pieces (10 set-up charge + 20-30 minutes of his time, plus the plywood) which I don't think is too unreasonable. I can pick them up when he's finished, which means that I'll save a few Pounds on delivery. The plywood is of laser-cutting grade (whatever that means).
Hopefully they'll be of decent quality...
posted on 22/9/11 at 04:58 PM Reply With Quote
Well - they're made...
I'm pleased - they're very well made, IMHO.
The only down-side is that my house now stinks of charred plywood.
[Edited on 22/9/11 by David Jenkins]
Alan B
posted on 22/9/11 at 05:23 PM Reply With Quote
David,
I appreciate you posting pics of the finished items. It kind of gives closure to the thread instead of leaving people wondering how things turned out.
Cheers, Alan
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger   Alan+B 's Yahoo
sdh2903
posted on 22/9/11 at 05:32 PM Reply With Quote
What are they for?
posted on 22/9/11 at 05:53 PM Reply With Quote
They are the centre plates for a quadcopter - see here for more details.
They can also be used for an octocopter... 8 motors, 8 props! Too scary for me...
