Vauxhall X20XEV 'Ecotec' - 200bhp engine
Vauxhall 2 litre X20XEV Ecotec engine - with modifications to produce ~200bhp.
I didn't build the engine (an ex? LCBer did), so cannot directly vouch for the spec, but my understanding of it is as follows:
- 2.0 X20XEV Ecotec block
- VX OPC head, heavily ported by Autocraft SVT.
- Autosprint 276 degree Fast Road/Competition 3500-7500rpm cams (hydraulic).
- VX OPC pistons (pocketed on inlet side).
- C20XE redtop rods (stronger than Ecotec).
- C20XE redtop big end bearing shells.
- QED vernier pulleys.
- QED inlet manifold.
- Weber Alpha Gold throttle bodies & ECU.
- FWD Astra engine loom.
- Manta winged alloy sump for RWD installation.
I don't know much about Vauxhalls, but it is estimated to be producing something like 190-200bhp. It was apparently dynoed at 190ish before the
cams were put in. It certainly has alot of grunt, but would probably benefit from a bit of fine tuning, and I think maybe needs the rev limit tweaking
in the ECU to get the best out of the cams (I've not revved it beyond 6.5k).
It is mated to a Getrag Manta gearbox (which actually has a lovely shift action!), via a Manta flywheel and clutch which is smaller and lighter as
standard than the redtop XE versions, which can also be included in the sale.
There's a prop (Manta gearbox to English axle) and exhaust manifold (needs some attention due to someone doing some horrid welding attempts to
fix possible pinholes) that can go with it too.
To be perfectly honest, I'm not too sure what it is worth, but it is not just a standard scrappy XE, and would cost quite a bit of money to
build it up from scratch - for example the TBs and ECU alone would cost in excess of £1k.
I'll take £1500 for a quick sale to get it out from under my feet. I think that is a fair price for some good power, it just needs a little
loving to get it running sweet. Or I may split if anyone has interest in some specific parts. Or if I'm way out on price, give me a hint!
Buyer collects or I can get it onto a pallet for a courier. Note that I am keeping the small alternator to go onto my new engine, so it is excluded
from this sale.
DH2
