Author: Subject: 4XV Cooling system
typ17
posted on 4/12/11 at 11:44 PM Reply With Quote
4XV Cooling system
Did a very elaborate and detailed diagram of what I think should be the cooling system for my R1 4xv engine.
But I'm not sure where the breather pipe that is in the inlet of the water pump is supposed to go to... ( top of the header tank maybe?!?)
Any help is very welcome.
Thanks again.
Jose
typ17
posted on 6/12/11 at 09:10 PM Reply With Quote
no reply
Could really use some help, anyone?
Thanks.
Jose
afj
posted on 6/12/11 at 09:47 PM Reply With Quote
thats looks ok was it drawn by a child the small one from the water pump goes to the throttle bodys on the 2003 r1 so i guess it goes to the carbs on your one
R1 Plumbing
R1 Plumbing
[Edited on 6/12/11 by afj]
eerrrrrrrrrrrrrrrr
typ17
posted on 6/12/11 at 10:16 PM Reply With Quote
thanks for your reply,
on the carbs there is no water cooling ...
If I was using the original radiator it would be connected to the midle of the radiator.
Anyone with a 4xv engine out there??
001Ben
posted on 6/12/11 at 10:34 PM Reply With Quote
ive got a 2001 r1 engine and it is plumbed in as afj has shown, just without the small pipe to the carbs and the pipe from the header goes to the top of the thermostat too - forget about the radiator
