<<  1    2  >>
New Topic New Reply
Author: Subject: Front Engine Kit Chassis Converted to Midi Layout???
posted on 9/1/12 at 04:04 PM Reply With Quote
Has anyone ever taken a front engined kit chassis and converted it to midi?
My tiny brain is in overdrive again and I've come to the (temporary) conclusion that it should be fairly straightforward...
... measure lots
... narrow the trans tunnel
... take a bit off the front
... add a bit on the rear
Job done!!!
Anyone have any real-world experience on such a matter (instead of my airy-fairy it's-a-piece-of p** logic ).
Or do I just buy Ed99's old Global chassis and see if I can adapt it to take a car engine!
It's Evolution Baby!
loggyboy
posted on 9/1/12 at 04:12 PM Reply With Quote
By the time you have dismanteled it, you might as well start from scratch!
eddie99
You buy my old global chassis and adapt it for a car engine. Sorted Only needs extending a tad
Simples...
[Edited on 9/1/12 by eddie99]
jossey
posted on 9/1/12 at 04:16 PM Reply With Quote
+1
although your description of how easy it is to do sounds very easy.
David Johnson
stevebubs
posted on 9/1/12 at 04:20 PM Reply With Quote
... measure lots
Job done!!!
Fury Menace did exactly this - kept the old outer chassis rails and reworked the inner ones.
posted on 9/1/12 at 04:21 PM Reply With Quote
Simples...
I just need to get some prices for Global components to see if it's a go-er Ed... wishbones, racks, etc!
ali f27
posted on 9/1/12 at 04:27 PM Reply With Quote
If your building a chassis dont see why you couldnt narrow tunnel to get more room and move the diff mount seat panel frame part forward leaving more at the back overall dims would be same as book but would have to narrow scuttle and shorten bonnet very interested if you have a go
ALI
posted on 9/1/12 at 04:35 PM Reply With Quote
Cheers Ali
It seems quite straightforward in my head because I'd (hopefully) be starting and working within a 'straight' structure.
TimC
posted on 9/1/12 at 04:41 PM Reply With Quote
Would it not be worth looking at a MK Midi or Sylva RIOT chassis?
ali f27
posted on 9/1/12 at 04:55 PM Reply With Quote
Hi Scootz are you going down m6 past penrith on friday think we are going to auto sport on thursday
posted on 9/1/12 at 05:02 PM Reply With Quote
Probably, but I'd need to shift the registered F27 chassis before I could afford to buy a brand new chassis.
We're flying down Ali.
ali f27
posted on 9/1/12 at 05:06 PM Reply With Quote
Bang on you fly striaght over me maybe you could paracute the tank out
posted on 9/1/12 at 05:10 PM Reply With Quote
posted on 9/1/12 at 05:35 PM Reply With Quote
Meant to add that I'm not all that convinced about the strength of the rear-end of the MK Midi...
big_wasa
posted on 9/1/12 at 05:51 PM Reply With Quote
does that mean the kv6 has been shelfed ? Did you get as far as getting the engine ? Ive just bought a very rare toy to sit on the top of mine
zilspeed
posted on 9/1/12 at 06:05 PM Reply With Quote
The ability to think in three dimensions is not given to everyone, clearly.
posted on 9/1/12 at 06:07 PM Reply With Quote
Nope... KV6 is sat in my garage!
I'm struggling to find an 'off the shelf' bellhousing to use it longitudinally, so I'm exploring the option of going transverse in a midi set-up using either the PG1 or Getrag 283 boxes.
[Edited on 9/1/12 by scootz]
posted on 9/1/12 at 06:13 PM Reply With Quote
I can indeed think in 3D Zil, but I'm still not all that convinced that the MK back-end would be too happy with an engine / gearbox combination sat in it that weighs 3 times that of the intended bike-engine application and puts down almost 3 times the torque.
zilspeed
posted on 9/1/12 at 06:24 PM Reply With Quote
Scootz
I wasn't talking about you.
After all, you never imposed that chassis upon the world.
I'm not a fan of this at all.
zilspeed
posted on 9/1/12 at 06:27 PM Reply With Quote
Regarding that engine.
Where do you want the weight of the car to be ?
Think of it that way.
Percentage wise, what do you want each tyre to take ?
posted on 9/1/12 at 06:29 PM Reply With Quote
Scootz
I wasn't talking about you...
LOL. Stick... End... Wrong!
MakeEverything
posted on 9/1/12 at 06:33 PM Reply With Quote
That's what I thought. Welding is as good as mine too!!
Kindest Regards,
Richard.
mark chandler
posted on 9/1/12 at 06:49 PM Reply With Quote
I,ve seen them in racing landrovers bolted up to Series 3 gearboxes, it was years ago cannot tell you if they had adpators
posted on 9/1/12 at 07:09 PM Reply With Quote
Cheers Mark.
I've established that the KV6 has the same engine to bellhousing bolt pattern as the Rover 'T' series engine... and therefore the 'O' series too... so that leaves only two RWD options. The Rover SD1 (2 litre engine variant) or the Sherpa (prima perkins engine variant).
Neither come up for sale often, and both have anchor-heavy (20kg's) iron bellhousings.
<<  1    2  >>
New Topic New Reply
