<<  1    2  >>
New Topic New Reply
Author: Subject: Chassis Panels & Adhesives
posted on 16/1/12 at 09:58 AM Reply With Quote
I suspect that 'sealing' the panels will be some kind of IVA requirement (?), but assuming you were to build a car for track / race use, or simply refurbishing a registered car... would you choose to seal the ali chassis panels with an adhesive and then rivet, or would you forego the adhesive and just rivet them on!?
I only ask as I've removed the old (sealed) panels from a number of cars now and it's an absolute PITA... and invariably leads to scoring the chassis!
[Edited on 16/1/12 by scootz]
It's Evolution Baby!
Irony
posted on 16/1/12 at 10:06 AM Reply With Quote
I removed the panels on my car and it was a PITA. I was planning on putting them back on with sikaflex and rivets but I know that at some point I will want them off again. Would it be possible to use some sort of self adhesive rubber trim along the straight lengths and just sikaflex into the corners???
welderman
posted on 16/1/12 at 10:15 AM Reply With Quote
QUOTE
Dont i know it lol
[Edited on 16/1/12 by welderman]
Thank's, Joe
I don't stalk people
wylliezx9r
posted on 16/1/12 at 10:27 AM Reply With Quote
Didn't fit any sealent on mine and rivnutted them on, no problems so far. I guess you could use double sided tape in lieu of the sealent.
George Best
wilkingj
posted on 16/1/12 at 10:32 AM Reply With Quote
I have always been under the impression that the point of bonding the panels to the chassis is to give added strength to the overall construction.
Luego definately told me this was what should be done. Sikaflex by choice, or any similar bonding goo. eg Tigerseal
http://www.paints4u.com/pdffiles/tigerdata.pdf
But NOT Bathroom type silicone goo.
It performs the function of helping to maxmimze the ridgitiy of the chassis.
Would you want your Kit to be built to a lower standard / strength?
IMHO Its definately BOND & RIVET
Best Regards
Geoff
http://www.v8viento.co.uk
loggyboy
posted on 16/1/12 at 10:42 AM Reply With Quote
No IVA requirement as far as im aware.
I use sikaflex on mine, did it to water proof the internal space (I know its open top) but didnt want road spray etc working its way into the car, and also in to the chassis and rotting it.
Interstingly Martin at Raw said not to bother!
[Edited on 16/1/12 by loggyboy]
rost
posted on 16/1/12 at 10:45 AM Reply With Quote
2nd on the strengthening here!
The rivets will loose strength over time and might even break at some point. Adding sealant will increase strength, but also durability.
Charlie don't surf!
Irony
posted on 16/1/12 at 10:47 AM Reply With Quote
I heard somewhere on Locostbuilders that the ally panels give the chassis extra rigidity and stiffness. Thats why some folks have gone for the Honeycomb ally panels apparently. They are supposed to add strength and rigidity.
l0rd
posted on 16/1/12 at 10:49 AM Reply With Quote
what about mastic?
The rubbery seal you have on doorcards?
posted on 16/1/12 at 10:50 AM Reply With Quote
Rivnuts?
Do you have any pics of the finished article?
posted on 16/1/12 at 10:51 AM Reply With Quote
QUOTE
Dont i know it lol
Soz!
Chippy
posted on 16/1/12 at 10:56 AM Reply With Quote
Using some form of mastic, of whatever type, not only adds strength, but also forms a barrier between the steel chassis and the ally panels to stop electrolasis, (sp), between disimilar metals. So as far as I am aware that makes it an absolute essential. IMHO Ray
welderman
posted on 16/1/12 at 01:14 PM Reply With Quote
Originally posted by scootz
QUOTE
Dont i know it lol
Soz!
No bother mate, its all part of the fun, and when you start ending up with panels like this, im happy.
picture taken with my phone so its not perfect, (nearly mind)
[img][/img]
Also to add, panel is bonded and rivited
Thank's, Joe
posted on 16/1/12 at 01:19 PM Reply With Quote
Bare
posted on 16/1/12 at 05:06 PM Reply With Quote
IMO an utter waste to add Glue Goo, V much like wearing double Condoms.
Apply some seam seal if water ingression is your perceived problem.
Although in 12 years of owning a Series 3 Seven, it was Never a problem I experienced.
As stated it makes a horrid mess if one needs to remove a panel.
[Edited on 16/1/12 by Bare]
posted on 16/1/12 at 05:28 PM Reply With Quote
I seem to recall that the Caterham I had a few years back didn't have any sealant under the panels!
Angel Acevedo
posted on 23/1/12 at 10:27 PM Reply With Quote
I used 3M Double sided tape to fix a Moulding that goes between the hood and attaches to the windshield on a Pickup truck and it was pretty solid, it may be easier to remove than Sikaflex or the like, but may be what you are looking for.
HTH
AA
ashg
posted on 23/1/12 at 11:02 PM Reply With Quote
QUOTE
Dont i know it lol
Soz!
[img][/img]
joe you really should put a not safe for work title up if your planning on posting up porn
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 24/1/12 at 09:57 AM Reply With Quote
Get some sticky backed Velcro and fit them with that, they should come off easily then
TimC
posted on 24/1/12 at 10:33 AM Reply With Quote
Fair-play Joe, that is going to look Uber-schweet when finished.
Steve Hignett
posted on 24/1/12 at 11:00 AM Reply With Quote
It bloody well should!!!
welderman
posted on 24/1/12 at 01:43 PM Reply With Quote
Thanks for comments boys, heres the inside of same panel
[img][/img]
Thank's, Joe
Neville Jones
posted on 25/1/12 at 04:01 PM Reply With Quote
With all that carbon, I'd be putting some small zinc pieces well connected to the chassis, at various points around the chassis. Sacrificial anodes.
Nev.
RK
posted on 2/2/12 at 12:38 PM Reply With Quote
A bit OT, but how on earth do people get that nice, shiny surface when doing CF? Mine always have bumps and rough bits, no matter how much wax I put down, and how much I polish ahead of time. And I've done it on glass as well as ally and plastic/polycarbonate. The best was from ally and glass with no wax or release agent. Could it be temperature isn't high enough? I've seen all the videos and I see nice, shiny, smooth parts coming out of the moulds. But this just is not my reality!!
ps wet lay, wrapped in plastic after. Don't seem to get an excess of resin.
[Edited on 2/2/12 by RK]
jacko
posted on 2/2/12 at 05:14 PM Reply With Quote
If you look at new buses the panels are only sika-flexed on apart from four 1/8 pop rivets in the corners
guess how i know
jacko
<<  1    2  >>
New Topic New Reply
