Author: Subject: A-arm bushes
Jonas
posted on 18/1/12 at 12:38 PM Reply With Quote
A-arm bushes
Hi!
Im building a Luego Velocity kit bought many years ago.
I have managed to lose one of the A-arm bushes.
I rather not buy a complete kit as I only need 1 (half), does anybody have 1 or 2 that I can buy?
RedAvon
posted on 18/1/12 at 12:55 PM Reply With Quote
I have some metalistic suspension bushes I have taken out of my Tiger Avon as I'm swapping to the nylon type bush.
They have been inserted and removed but not used on the road - as the car is unfinished. If you can find out if these will fit your suspension I'll send them to you for the cost of the postage.
Ian
Jonas
posted on 18/1/12 at 01:40 PM Reply With Quote
Thanks, but the bushes I need are the black nylon type (as supplied by Luego).
posted on 18/1/12 at 08:13 PM Reply With Quote
Can't help with any bushes but if you haven't already seen it do a search on here for crush tubes , It may save you loads of grief.
Jonas
posted on 18/1/12 at 09:50 PM Reply With Quote
Im aware of the crush tube problem (if you mean they are to tight?)
I have solved it by turning down the flanges on the bushes in a lathe.
Steve Lovelock
posted on 30/1/12 at 10:33 PM Reply With Quote
The best solution is to throw the hard plastic bushes away and by proper bushes along with stainless crush tubes from a respectable company. I know it is expensive but it is the best way.
MakeEverything
posted on 30/1/12 at 11:00 PM Reply With Quote
I have a spare pack of bushes with crush tubes, but they are blue powerflex ones. Will also need to confirm dimensions!
Kindest Regards,
Richard.
Jonas
posted on 31/1/12 at 08:24 AM Reply With Quote
Thanks Richard, might be interested if I cant find Luego ones, sent a PM.
MakeEverything
posted on 1/2/12 at 08:28 AM Reply With Quote
U2u replied.
Kindest Regards,
Richard.
